> Breaking news. lol, Celicarocker calls me at 1:14Am
post Apr 4, 2005 - 12:22 AM
x_itchy_b_x
Joined Nov 12, '02
From Webster Ma.
Well im trying to sleep buy jons friggen St celica was going down the road and then made weird noises so he says then just shut off totally. i heard the car cranking over the cell phone. to me it sounds like either fuel or spark. ie fuel pump or coil, distro cap. any input. i feel bad lol hes stranded now. the cars is cranking fine which rules out battery or the altinator. he said he smells a sort of buring smell wich could be the coil my guess. so yeah any input?
post Apr 4, 2005 - 7:37 AM
1bwilson
Joined Aug 30, '02
From Maryland
rod bearing
Member of Team 5sfTe
post Apr 4, 2005 - 8:25 AM
x_itchy_b_x
Joined Nov 12, '02
From Webster Ma.
maybe when it was cranking over it sounded horrible.
post Apr 4, 2005 - 9:08 AM
BigEdge169
Joined Nov 18, '02
From Texas
mine died last week too, apparently my distributer was completely blown...
post Apr 4, 2005 - 9:40 AM
politicsareevil
Joined May 1, '03
From Houston , Texas
Mine died not to long ago, Turns out my distributor was on fire. Yay Fire. More than likely the distributor.
just my input,
Matt
post Apr 4, 2005 - 10:39 AM
celicarocker
Joined Sep 25, '03
From cranston RI
haha... i was just coming here to make a post to get some input... i had it towed to a place at like 3am by AAA... the guy agreed with me that it looks like its just not getting any fuel, but im going to go to the place and drop off my keys so they can just fix my car... but how much does a fuel pump cost to replace if that is it?
post Apr 4, 2005 - 11:20 AM
x_itchy_b_x
Joined Nov 12, '02
From Webster Ma.
id imagine around a hundred for a pump? labor is not much at all. its just a few wires and hoses under the back seat.
post Apr 4, 2005 - 11:24 AM
nik
Joined Sep 30, '02
$100 for the pump
$110 @ 55 an hour labor
tax
around 250-300 i'm guessing
post Apr 5, 2005 - 9:38 AM
celicarocker
Joined Sep 25, '03
From cranston RI
well.... i payed to have it diagnosed since i really wanted a quick fix becuase i really need my car. unfortunatley it isnt the distributor or the fuel pump frown.gif somehow, the timing belt ive had on the car for less than 2k miles got shredded... the guy then started rambling off all this stuff that "should" be done, and i just got lost in his rambling... so im having my step father whos a mechanic call them this morning and find out what it really needs... cuz he quoted me at $1500 on what "should" be done, which is rediculous, coincidering i just put $600 into it... my cars not even worth $2100 lol... damnit this sucks....
post Apr 5, 2005 - 11:40 AM
946thGenGT
Joined Oct 4, '04
If the timing belt was only on for 2k miles do you have some sort of warranty from the shop that put it on or even from the manufacturer?
post Apr 6, 2005 - 3:26 AM
Silvan
Joined May 7, '04
From Leeuwarden, Netherlands
too bad, but I don't think you have any warranty. If you change the timingbelt, you're advised to replace belt tensioner and pulley's also.
Manufacturers have themselves covered against claims due to things like this.
post Apr 6, 2005 - 11:26 PM
celicarocker
Joined Sep 25, '03
From cranston RI
well i have my step father do all my work, he has a shop in CT... im having it towed back there tomorrow, so hopefully i should have it back in less than a week he said...
post Apr 7, 2005 - 4:47 PM
celica3sgte
Joined Nov 12, '02
From Columbus, Ohio
timing belts are no fun.
This post has been edited by celica3sgte: Apr 7, 2005 - 4:49 PM
post Apr 7, 2005 - 5:03 PM
1bwilson
Joined Aug 30, '02
From Maryland
QUOTE(celica3sgte @ Apr 7, 2005 - 2:47 PM)
[right][snapback]267910[/snapback][/right]
On the 5sfe the timing belt is easy. Its the cover thats a PITA.
post Apr 7, 2005 - 5:19 PM
celica3sgte
Joined Nov 12, '02
From Columbus, Ohio
It's just like the 3s right? Undo the pass motor mount, remove crank pulley, then timing belt cover, and work in tight spots.
post Apr 7, 2005 - 5:38 PM
Drocay
Joined Oct 3, '02
From Va Team 6gc
that sucks bro, hope u get your car back soon.
Team 6gc 2005
post Apr 11, 2005 - 8:50 PM
celicarocker
Joined Sep 25, '03
From cranston RI
well i brought my car to my stepfathers on saturday... i can pick it up on wednesday... the tensioner siezed up which caused the timing belt to shred itself pretty much... nothing else was damaged. so all i need is a new tensioner and timing belt.
Lo-Fi Version Time is now: December 12th, 2024 - 2:40 PM
