Hey 3s swappers |
Hey 3s swappers |
Apr 6, 2005 - 2:04 PM |
Enthusiast Joined Nov 12, '02 From Columbus, Ohio Currently Offline Reputation: 15 (100%) |
I've got the 2nd gen 3s in a 6g. I used the st and 3s fuel line(fuel filter to the fuel rail), and spliced them together. What did you guys use? Will the gt fuel line work?
Apr 6, 2005 - 3:35 PM |
can you post a pic of your setup? it seems kind of strange that you had to splice any of those lines.
on my car i just have the stock 3sgte fuel line connected to my 5sfe fuel filter. the fuel line is a little too short, but you can work around that by only bolting your fuel filter with one bolt and bending the bracket a little. -------------------- 15PSI - 30MPG - Megasquirt Tuned
Apr 9, 2005 - 2:56 PM |
Here is a pic right off of the fuel filter.
Apr 9, 2005 - 4:41 PM |
hmm. strange that u did it that way. i just used the stock 3s line.
Apr 10, 2005 - 9:32 AM |
isnt stock 3s line too short?
Apr 10, 2005 - 10:13 AM |
the stock 3s line is a little short, but all you have to do is unbolt your fuel filter from the chasis and move the line closer. then after you connect everything, you can bolt the fuel filter back up using only one bolt and bending its bracket a little.
Apr 10, 2005 - 12:28 PM |
I didn't want the fuel filter bouncing around. No one used the GT line??? I think I'm going to have a shop make me one to fit.
Apr 10, 2005 - 1:29 PM |
let me know what you come up with. id like to have mine the proper length.
Apr 10, 2005 - 1:36 PM |
Enthusiast Joined Jan 1, '03 From LB gizzie, cali Currently Offline Reputation: 0 (0%) |
i accidentally cut my 5sfe...so i did what you did..i just connected the 3sgte line with the 5sfe line... and yup the 3sgte was too short thats why i ended up cutting it
This post has been edited by Ryu3x16: Apr 10, 2005 - 1:38 PM -------------------- [color=#FF0000] I MISS MY RED BABY =(
Apr 11, 2005 - 12:37 AM |
Now I have the big turbo on there. At 9psi it runs out of fuel and starts sputtering. Granted I still have stock injectors. An upgrade is needed. However, with the fuel spliced I used a coupler inside, which reduces the inside diameter of my fuel line a little bit. I'd say under 1/8". This isn't much, but it still restricts flow just a bit. I'm going to remove a bunch of stuff like throttle body and piping to remove the fuel rail. So I guess I'm definetely going to take off the whole fuel line and take it somewhere and see what they can do. Actually, what if we got some longer bolts and made 2 block extensions which would bring the fuel filter closer to the motor. Who knows how short the 3s line is? Maybe we can just extend the bracket.
Apr 11, 2005 - 7:57 AM |
QUOTE(lagos @ Apr 10, 2005 - 2:29 PM) let me know what you come up with. id like to have mine the proper length. [right][snapback]269101[/snapback][/right] Ditto. I'm using 3s line. -------------------- |
Apr 11, 2005 - 10:41 PM |
Enthusiast Joined Jun 21, '03 From Pennsylvania Currently Offline Reputation: 3 (100%) |
You only need like 2" more length on the 3s line to get it to bolt to the filter.
I would make a 3-4" spacer if you plan on doing that because the stock engine mounts flex a good bit. you dont want it to just make it and then get pulled off when you hammer down lead foot! DG -------------------- |
Apr 13, 2005 - 1:50 AM |
You're right. Now we're into the issue of 4" bolts(that aren't thick in diameter) holding too much weight. I'm gonna take the line somewhere and see what they can do. Let you guys know in about 2 weeks.
Lo-Fi Version | Time is now: November 29th, 2024 - 5:29 AM |
