> Brake Lights not working!!!
post Apr 11, 2005 - 4:41 PM
Snyper94GT
Joined Jan 14, '04
From Kentucky
Here's my problem none of my 3 brake lights are working. I've checked every fuse I can find and none of them are blown. I was going to check the brake light switch to see if it was working but I couldn't find it. So anybody know where that is or what might possibly be the problem. Any help would be great. Thanks!
post Apr 11, 2005 - 4:53 PM
When I get home I can take a pic of the +12v brake light switch wire for you to test. It's a green/white wire from what I remember, and I tapped the wire in my driver's side kick panel.
Moved to a more appropriate forum.
post Apr 12, 2005 - 9:35 PM
maghouin
Joined Apr 12, '05
I'm having the same problem... Would love to see your input, Coomer. smile.gif
post Apr 16, 2005 - 1:18 PM
cyb593
Joined Feb 22, '04
From USA
i had a problem with that to. well with mine was the solenoid in the automatic shifter. but my shifter u couldnt even move half the time till i got it fixed are u having trouble dropping it out of park??? u had to rip mine out. and the times i didnt rip it out of park they lights worked fine but when i did rip it out of park they didnt work. just something to think about.
post Apr 17, 2005 - 9:18 AM
flipside97LTD
Joined Nov 29, '03
From Hampton, VA
I had a similar problem at one time. You should first of all, check to see if the bulbs have burned out. Second, check that the wires are making a good connection where they plug into the rest of the cars wiring. Just take the trunk panels out and give it a look.
Lo-Fi Version Time is now: November 26th, 2024 - 8:31 AM
