> 3sgte oil pan
post Apr 12, 2005 - 2:18 PM
fastgt
Joined Feb 13, '03
From California
well i have a leak in my oil pan gasket , and since im going with the 5sfte ima need the 3s pan....but im not ready to put the turbo on, so is there a way to plug the oil pan temporarily . i really dont wanna take that pan off twice
by the way i dont have the oil pan in my hands yet
This post has been edited by fastgt: Apr 12, 2005 - 2:19 PM
2011 Spice Orange Mini Cooper
2011 Alpine White BMW E92 M3
gone but not forgotten
2008 Space Grey BMW Z4 ///M
post Apr 12, 2005 - 2:35 PM
rjbibeau
Joined Sep 6, '04
From oakdale Mn
you don't need a 3sgte pan. just put a bulkhead fitting in the pan when you take it off. you can cap off the fitting to when you'll need it. if your goin stainless steel lines. use a -12an bulkhead fitting. and for the feed a -3an line. pm me if you have any more questions since i have ran stainless lines.
post Apr 12, 2005 - 2:49 PM
fastgt
Joined Feb 13, '03
From California
hmmm that sounds good.. but is there a way to plug the 3s pan temporarily..
oh do you have pics rj??
post Apr 12, 2005 - 2:56 PM
rjbibeau
Joined Sep 6, '04
From oakdale Mn
ya let me upload a sec
post Apr 12, 2005 - 3:03 PM
rjbibeau
Joined Sep 6, '04
From oakdale Mn
here's the bulkhead fitting. no welding required.
here's my custom flanges made from aluminum made by me and a angle grinder and a npt tap set.
This post has been edited by rjbibeau: Apr 12, 2005 - 3:07 PM
post Apr 12, 2005 - 3:11 PM
fastgt
Joined Feb 13, '03
From California
thanks man
post Apr 12, 2005 - 3:22 PM
rjbibeau
Joined Sep 6, '04
From oakdale Mn
no problem bro
post Apr 13, 2005 - 12:22 AM
Newbie
Joined Nov 3, '04
From Colorado
You think you could make those flanges for me? Just a question..
post Apr 13, 2005 - 12:38 AM
Punch
Joined Jan 29, '04
From Brooklyn moved to Miramar Florida
you can do it your self go to a performance shop & get that bulkhead fitting. get a TAP&DIE set....
post Apr 13, 2005 - 1:00 AM
rjbibeau
Joined Sep 6, '04
From oakdale Mn
ya the flanges were pretty easy to make. i just traced the gasket. and went at it with the angle grinder. just to let ya know npt tap is as bisnatch to tap out cuz it's tapered. took me a few trys on scrap aluminum.
post Apr 13, 2005 - 1:02 AM
rjbibeau
Joined Sep 6, '04
From oakdale Mn
ohh ya and definately get a drill press
post Apr 13, 2005 - 1:09 AM
Newbie
Joined Nov 3, '04
From Colorado
Hmm.. Mind making those for me? You make it sound like it's really hard...
post Apr 13, 2005 - 9:04 AM
hey rjb, good job on the flange and lines! i know when you first made the flange it looked crude, but all that matters is that it works! as long as it dont leak, its ALLLLL good !! wink.gif
post Apr 13, 2005 - 1:32 PM
rjbibeau
Joined Sep 6, '04
From oakdale Mn
hey thanks for the compliment pressure. ya the coolant flanges turned out perfect. but i had a problem with the oil one. being that the an fittings were so huge being a size 12 and all i had to angle to feed line so that it won't collide with the return line allowing me to screw it on. then i jb welded the fitting and she is strong as heck. as long as it works. ya i'll see what i can do i think i have some scrap aluminum left over. it's 1/2" thick. what i suggest to do though is welding the fittings in there but aluminum is pretty hard to weld but i think that would be the most efficient way cuz pipe thread really sux to tap.
Lo-Fi Version Time is now: February 18th, 2025 - 4:56 AM
