Mobil 1 1500 oil, wow |
Apr 13, 2005 - 11:08 AM |
I just did a oil change and put in the new mobil 1 1500 syntetic motor oil and wow is all i got to say. this stuff is sooo nice and runs soo smooth.
Apr 13, 2005 - 12:19 PM |
You mean 15,000... I'm pretty sure its just regular synthetic mobil 1, but now they can flaunt the 15K part.
Apr 13, 2005 - 2:11 PM |
Yaa, 15000, its a new blend that is suppose to be the best out there.
Apr 13, 2005 - 2:19 PM |
is it true that once you go synthetic you can't go back to regular oil ?
Apr 13, 2005 - 2:27 PM |
Enthusiast Joined Feb 3, '05 From Portland, OR Currently Offline Reputation: 0 (0%) |
I keep hearing about all these new synthetics. I have been runing redline fully synthetic in my car since I did the swap, anyone know how these oils compare to it
Apr 13, 2005 - 2:38 PM |
yes you cant go back once you go synthetic.
Apr 13, 2005 - 3:20 PM |
Synthetics have been able to go that long before, its just been kept hush hush. They say "new blend" but I doubt the 15K version is much different, it at all, of the standard Mobil 1 thats been out for awhile. Amsoil has had synthetic out that could go 30K but gov't but the kybash on it.
Apr 13, 2005 - 3:31 PM |
Enthusiast Joined Oct 10, '04 From New Jersey Currently Offline Reputation: 0 (0%) |
i wouldnt trust any oil that would last 15K, all that heat and were all that time, i wouldnt trust it
Apr 13, 2005 - 4:35 PM |
Enthusiast Joined Jun 2, '03 From Annandale VA Currently Offline Reputation: 0 (0%) |
I wouldnt trust the filter to keep it clean for that long.
Apr 13, 2005 - 4:51 PM |
if you take off your filter with the oil in the motor you don't lose much oil 3oz max...so you change the filter 3 times but oil once lol!
it will hold 15k easy but yea i'm switching over to redline do to the fact its the best oil out there right now performance wise from what reviews i've read |
Apr 13, 2005 - 5:41 PM |
i've been changing my moble one synthetic oil every 3k miles.. the oil looks exactly the same color as the new oil. But the engine runs smoother after I changed the oil. I just dont trust the oil being in the engine that long.. i think it thins out.
Apr 13, 2005 - 7:47 PM |
Well thats corporate brainwashing. They come out with a motor oil guaranteed for 15K and you guys are still stuck on 3. Standard oil can go longer than 3k so your synthetic can go much longer, regardless of whether you "trust" it.
Apr 13, 2005 - 8:21 PM |
QUOTE(Batman722 @ Apr 13, 2005 - 2:19 PM) is it true that once you go synthetic you can't go back to regular oil ? [right][snapback]270703[/snapback][/right] no thats not true .. -------------------- |
Apr 13, 2005 - 8:44 PM |
Enthusiast Joined Sep 22, '03 Currently Offline Reputation: 0 (0%) |
doing oil change soon.. Should I go for it or stick with my castrol??
This post has been edited by hyp3rk1d: Apr 13, 2005 - 8:44 PM |
Apr 13, 2005 - 9:00 PM |
I personally switch to synthetic when I hit 100K.
Apr 14, 2005 - 4:00 PM |
i used castrol gtx before i switched and im glad i did, i really really like the synthetic.
Apr 15, 2005 - 1:12 AM |
Enthusiast Joined Dec 4, '03 Currently Offline Reputation: 0 (0%) |
QUOTE(StreetRacing10PSI @ Apr 13, 2005 - 3:31 PM) i wouldnt trust any oil that would last 15K, all that heat and were all that time, i wouldnt trust it [right][snapback]270779[/snapback][/right] thats where your wrong, normal Mobil 1 can go for 5k easily even tho its darker its working fine. --- this is straight from the horses mouth, my uncle is a rep for them and is up there in their business, hes doing quite well financialy. QUOTE(slipgun @ Apr 13, 2005 - 4:35 PM) I wouldnt trust the filter to keep it clean for that long. [right][snapback]270818[/snapback][/right] u change the filter every 3k, and loose very little oil so you just top it off every time you change. -------------------- hows it taste motha f*cka
Apr 15, 2005 - 1:31 AM |
Enthusiast Joined Aug 31, '02 From KC Currently Offline Reputation: 0 (0%) |
QUOTE(Supersprynt @ Apr 13, 2005 - 1:20 PM) Synthetics have been able to go that long before, its just been kept hush hush. They say "new blend" but I doubt the 15K version is much different, it at all, of the standard Mobil 1 thats been out for awhile. Amsoil has had synthetic out that could go 30K but gov't but the kybash on it. [right][snapback]270756[/snapback][/right] The Government? more like the big oil companies and car companies, Amsoil has been recommending extended drain intervals since the '70s,,, and it was 25000 miles, 35000 on the newer series 2000 & 3000 oils, even longer with their bypass filter system and oil analysis. I've been doing it for over 20 years, never had a problem because of it. Amsoil is the largest manufacturer of synthetics and has been doing it longer than anybody else. More info at: Amsoil.com |
Lo-Fi Version | Time is now: December 4th, 2024 - 3:29 PM |
