3sgte axle |
3sgte axle |
Apr 14, 2005 - 10:47 AM |
Enthusiast Joined Sep 23, '04 From fresno Currently Offline Reputation: 0 (0%) |
those with 3sgte swap ..what kind of axle did you guys used?????
Apr 14, 2005 - 11:09 AM |
Enthusiast Joined Sep 30, '02 From Washington Spokane / Coeur D' Alene Idaho Currently Offline Reputation: 11 (100%) |
QUOTE(st_celica_killer @ Apr 14, 2005 - 8:47 AM) those with 3sgte swap ..what kind of axle did you guys used????? [right][snapback]271277[/snapback][/right] what kind of tranny did you use or are going to use? from readon here if you do a MR2 tranny you have to do a hybrid axle mix the 5sfe outer part the and rod and inner of the mr2 axle some along those lines or you can use the gt tranny and axles you just need to be more clear about your question -------------------- yea your 3sgte is cool but ill stick to my 7agte
Apr 14, 2005 - 12:52 PM |
mr2 turbo tranny how about that!
Apr 14, 2005 - 2:08 PM |
Enthusiast Joined Mar 21, '04 From Oceanside Currently Offline Reputation: 2 (100%) |
With my 94 MR2 Turbo Tranny with LSD in the ST, I used a hybrid. An MR2 inner with an outer from a ST185 or Camry V6. I have read that there seems to be a difference between the Camry and the ST185 axle, but I had them both in my garage this weekend and measured...found no difference (possibly could have been given the wrong part or I got the wrong year - 1990). So I would say change the hub from the ST205 use the Camry Axle, as I believe Lagos did and it will fit better than on your stock hub. I unfortunately got a bad hub with my clip, so couldn't change it out. I had to go custom anf finally got something to work. However I have heard that a 89 Supra will give the extra length for proper fitting into the stock hub with the MR2 inner.
This post has been edited by Green_MachToy: Apr 14, 2005 - 2:13 PM |
Apr 14, 2005 - 3:06 PM |
Lagos is using a S54 tranny with stock axles.
I will be using MR2 E153 LSD inners with ST185 outters. -------------------- |
Apr 14, 2005 - 6:52 PM |
so how do you guys to that?? by taking the axle a part by useding the mr2 turbo axle or what???? also would it be cheaper if you just go custom axle useing a mr2 turbo tranny with custom axle ?????
Apr 14, 2005 - 8:05 PM |
No it wouldnt.
Lo-Fi Version | Time is now: December 1st, 2024 - 3:44 PM |
