Rear disc brake conversion |
Apr 10, 2003 - 3:42 PM |
Enthusiast Joined Sep 18, '02 From Northern, Virginia Currently Offline Reputation: 0 (0%) |
I was reading the How-to on the rear disc brake conversion, not quite clear on the parts needed, could someone clarify.
Parts: 1. Caliper from any 6th gen cel w/out ABS - do these have to be from a celica? 2. Rotor - check 4. Internal Brake components for parking brake - I can use the drum brake St parts for this right? 5. Backplate - whats this? 6. Parking brake cable from a 6th gen GT - heard you could use the one from the st. This post has been edited by coustoe: Apr 10, 2003 - 4:00 PM |
Apr 10, 2003 - 5:01 PM |
Enthusiast Joined Oct 1, '02 From North Bethesda, MD Currently Offline Reputation: 0 (0%) |
1) yes, you need to get some REAR GT calipers.
2) check 4) no, that's why it's on the list of stuff to get. it's like a mini-drum brake behind the disc brake. 5) the plate that goes in between the brake assembly and the rest of the car, if you look in the pics in the write up, you'll see what i mean. 6) no, you need one from a GT, the Ebrake is different (see #4) -------------------- 1994 Lexus ES300
1989 Supra Turbo 1990 RHD ST185RC - JDM Spec |
Apr 10, 2003 - 5:43 PM |
Enthusiast Joined Sep 5, '02 From Phoenix, AZ Currently Offline Reputation: 0 (0%) |
I talked to mike (Quatar11) and he said he's doin a kit for a drum --> disc conversion here in a couple weeks. I think he said Charlie97 is helpin him out too, not sure. So you might want to hold on and just buy the kit from them.
Apr 10, 2003 - 6:46 PM |
a rear disk brake conversion kit for the ST would be sick -------------------- |
Apr 10, 2003 - 6:50 PM |
calipers seem to be expensive, called the parts suppliers they want the original gt calipers back. I was quoted $60 then they said if i dont have the original calipers they gonna charge me $120.. Sick
Apr 10, 2003 - 6:58 PM |
qatars been working on the disc kit for ever now.
Apr 10, 2003 - 7:07 PM |
well if they messed up the order then that their problem don't give them anything. -------------------- |
Apr 13, 2003 - 9:26 PM |
Enthusiast Joined Apr 8, '03 From NorCal Currently Offline Reputation: 0 (0%) |
Won't the older gen parts work also? I think 4th and 5th gens parts should work... but then again, I've never attempted this mod. All I know is, 4th gens are pretty common at the junkyards around this area.
Apr 13, 2003 - 11:55 PM |
negative, 4th gens and 5th gen STs had 4 lug hubs. mike and i are working on a kit that will be available thru topshelfracing, now that i've gotten past my major schoolwork for the semester, i can start getting the ball rolling on my end. -------------------- 1994 Lexus ES300
Apr 14, 2003 - 1:23 AM |
WOOT!!!
Go Charlie! You da man! |
May 8, 2003 - 10:02 PM |
Enthusiast Joined Oct 15, '02 From Rochester, New York Currently Offline Reputation: 0 (0%) |
Just to bring this back up, did Mike (Quatar11) ever end up making a kit for the conversion?
Lo-Fi Version | Time is now: November 24th, 2024 - 5:55 AM |
