> mr2 tranny VS solara tranny, witch one is better?
post Apr 15, 2005 - 1:16 AM
trdevelopment
Joined Jul 27, '04
From phoenix az
hey guys im just wondering witch one of the two is better a solara tranny or a mr2? now i know the mr2 had a lsd option that was used in the latest years of the 3sgte in the mr2 but i dont know if the solora has lsd...? and would the solara tranny be a bit better then a regular gt tranny?
This post has been edited by trdevelopment: Apr 15, 2005 - 1:17 AM
post Apr 15, 2005 - 6:47 AM
Better for what? A 3sgte? I would think that the tranny designed for the 3sgte would be better. However the solara is already converted to FWD, not like its too hard to do the MR2. I dont think the solara has LSD, and its also got different gearing IMO not the best for 3s.
post Apr 15, 2005 - 2:22 PM
trdevelopment
Joined Jul 27, '04
From phoenix az
yeah a better tranny for a 3sgte...
post Apr 15, 2005 - 3:20 PM
jgreening
Joined Jan 17, '04
From Illinois
build wise they are the same. Make sure you get one with dual cone syncros. In the MR2T, its the 93+. I am not sure what year solars had the better syncros. Also, any aftermarket LSD that works in the MR2T tranny will work in the V6 Solara tranny from the 1999+- era. They are both E-153 transmissions.
post Apr 15, 2005 - 3:41 PM
StreetRacing10PS...
Joined Oct 10, '04
From New Jersey
i personally would go with a MR2 trans, there are a lot more after market parts for the trans available.
post Apr 15, 2005 - 4:10 PM
jgreening
Joined Jan 17, '04
From Illinois
QUOTE(StreetRacing10PSI @ Apr 15, 2005 - 3:41 PM)
[right][snapback]271967[/snapback][/right]
What aftermarket parts are you referring to? Like I said, the aftermarket LSD's fit both.
post Apr 15, 2005 - 4:17 PM
Clipsetuner
Joined Sep 12, '03
From Portland , Oregon , United States
The Solara has slighty differeint gearing but Im pretty sure its only 4th and 5th gears, better highway millege woot! I know that the first 3 gears are almost the same ratio as the 3sgteLSD tranny. I am using this tranny so Ill let you all know what I think of it.
Jgrenning - I wasnt aware that any LSD could fit the solara tranny, Have some links to support this?
DTE
I am a thief.
do not buy anything from me.
post Apr 15, 2005 - 5:07 PM
jgreening
Joined Jan 17, '04
From Illinois
Any MR2T LSD. Try the kaaz or quaife websites. I think you will find that the same LSD (model #) works for both the MR2T and Solara transmissions.
post Apr 17, 2005 - 3:41 PM
trdevelopment
Joined Jul 27, '04
From phoenix az
ok cool thanks. another question... what would be better to use a non turbo mr2 tranny (the celica gt tranny) or a solara tranny?
post Apr 17, 2005 - 4:11 PM
spunky393
Joined Apr 22, '04
From illinois
the solara training is stronger
post Apr 17, 2005 - 4:23 PM
jgreening
Joined Jan 17, '04
From Illinois
The Solara tranny IS stronger than the GT celica tranny. It is the same as the MR2T tranny in terms of strength. The nice thing about the solara tranny is that you do not have to convert the shifter forks and most used solara trannies have less milage. The only down side is the taller gears and some people claim thats an advantage. Oh yea, and the lack of OEM LSD.
This post has been edited by jgreening: Apr 17, 2005 - 5:18 PM
post Apr 17, 2005 - 5:19 PM
Consynx
Joined Dec 25, '02
From Pittsburgh/Clairton, PA
wow, good decipher, i thought he meant traning... (and one flew past me)
anyways,
dual cone synchros?(can you explain why two cones are necessary instaed of 1)
is it also the 93+ that have LSD?
post Apr 17, 2005 - 6:09 PM
jgreening
Joined Jan 17, '04
From Illinois
QUOTE(Consynx @ Apr 17, 2005 - 5:19 PM)
anyways,
[right][snapback]272751[/snapback][/right]
Syncro wear. The 91-92 MR2T trannies are notorious for problems after 100k miles. The 93+ are much better.
Lo-Fi Version Time is now: December 3rd, 2024 - 3:54 PM
