does anyone know how to put underdrive pulley on?, mine is still sitting around..... |
Apr 10, 2003 - 4:12 PM |
Enthusiast Joined Nov 13, '02 From So Cal Currently Offline Reputation: 3 (100%) |
so yea, that pulley group buy that went on a while back....i got mine and still dont have it on....and i dont wanna pay someone 100 bucks to put it on, so does anybody kno how to put it on by yourself??
Apr 10, 2003 - 4:51 PM |
Enthusiast Joined Oct 12, '02 From New Jersey Currently Offline Reputation: 0 (0%) |
I was going to get it but I heard it messes with your alternator so I never did it..did you ask on celica.net?
Apr 10, 2003 - 4:55 PM |
Enthusiast Joined Oct 1, '02 From North Bethesda, MD Currently Offline Reputation: 0 (0%) |
you have to take off the passenger fender, and you need a pulley puller and a belt tensioner. i dunno, i got mine put on for like 40 bucks. it shouldn't be a hundred. -------------------- 1994 Lexus ES300
1989 Supra Turbo 1990 RHD ST185RC - JDM Spec |
Apr 10, 2003 - 5:16 PM |
well it simple to put a pulley on if your now what you are doing.
you will need for sure a socekt and combination wrench set. a puller maybe. a torq wrench. and and a few other things just get someone that knows what they are doing to help you. -------------------- |
Apr 10, 2003 - 11:39 PM |
i had everything off, the bolts loosened, the belts taken off, etc. what is the pulley puller and do u guys know where i can get rent one?
Apr 11, 2003 - 12:09 AM |
autozone, pep boys, etc. -------------------- 1994 Lexus ES300
Apr 12, 2003 - 9:26 AM |
Enthusiast Joined Mar 6, '03 From South Central Los Angeles and Long Beach, CA Currently Offline Reputation: 1 (100%) |
What exactly do the pulleys do?? Do they had hp? If so how much?
Apr 12, 2003 - 10:44 AM |
Your engine turns the AC, alternator, and so on. The underdrive pulley turns them slower, thus freeing up power to use for speed.
Apr 13, 2003 - 7:46 PM |
Enthusiast Joined Apr 8, '03 From NorCal Currently Offline Reputation: 0 (0%) |
You don't need to do most of that...that's almost like killing a fly with a shotgun. =] Installation is a cinch on the ST...(if you have the tools...I did) Remove the passenger side front tire, and the inner plastic piece (or just the two top bolts and fold it down) After that, the pulley is exposed. Lossen belts, 3 bolts on alternator, 2 on ac compressor... remove belts. Take off main pulley bolt, pull out pulley with pulley puller... (note, I had a larger 3 claw pulley puller, which was too big... but I also had a smaller bolt in type puller, which worked...make sure your pulley puller isn't too big) Try not to dislodge the chuck key. Spray a bit of WD40 on the pulley chuck and on the pulley... slip on, making sure the key is in place... Torque down. Put on new belts, tension tight, but not too tight to where you can't flip the belt with your fingers. Tighten the rest of the bolts, and you're set. Enjoy... |
Apr 13, 2003 - 8:04 PM |
yea what he said
Apr 14, 2003 - 8:47 PM |
Enthusiast Joined Sep 28, '02 From Lancaster Ca Currently Offline Reputation: 0 (0%) |
how much do pulleys usually go for? are they worth the buck?
Apr 15, 2003 - 12:42 AM |
They usually run around 90-115 bucks. Nice increase overall, but nothing spectacular. http://www.rpmoutlet.com/aspimp.htm I got mine there 115 bucks shipped 2 days UPS... took almost a month, but it came. I guess it was on backorder or something. |
Apr 15, 2003 - 7:50 PM |
Enthusiast Joined Oct 3, '02 From Diego Currently Offline Reputation: 1 (100%) |
that's a nice price~. Thanx Kwanza.
Apr 15, 2003 - 11:16 PM |
Did it really make that much of a difference? Could you feel it and was it high or low end?
Apr 16, 2003 - 12:01 AM |
Enthusiast Joined Aug 29, '02 From ny to philly Currently Offline Reputation: 0 (0%) |
it doesn't increase power at any particular rpm. its more an overall increase throughout the range. while its not a HUGE difference by any means, there is definetly some more pep especially when the A/C is on.
Apr 16, 2003 - 12:03 AM |
what about when it is off?
Apr 16, 2003 - 12:09 AM |
like I said, its not all that noticeable. I believe there are gains, and I think its well worth it for the ~100, but its not like an intake where you hear the whooosh sound and think wow my car is going faster (which is a placebo effect btw). quite honestly you aren't going to feel a couple hp here or there, but in the end it DOES add up. every mod counts and an underdrive pulley is a step in the right direction.
Apr 16, 2003 - 1:34 AM |
Enthusiast Joined Apr 14, '03 Currently Offline Reputation: 0 (0%) |
Hey whats up guys Im new here, just found this website and man its what Ive been looking for. I just recently had the Unorthodox Pulley put on it cost a good 260 bucks but well worth it. There is a signifacant pull once you hit. Doing the math your current underdrive crankshaft pulley weighs almost 6 pounds and unorthodox pulley is about 1.4 pounds. Taking one pound away is a 2.7 HP gain so doing the math it all adds about 12 but thats probably to the crank but none the less it feels good. Remember to get all your belts and what not.
Lo-Fi Version | Time is now: November 24th, 2024 - 3:48 PM |
