> Changing timing on a 96+ celica ST, finally did the mod
post Apr 10, 2003 - 5:34 PM
97sccelica
Joined Aug 30, '02
From Anaheim, CA
Well i know that guys like Charlie wanted to know about this. here is the background info
on the 94-95 ST's the timing can be adjusted by loosening the bolt on the distributor and twisting it.
on the 96+ celica ST's with PIA obd2, the distributor is locked. the mounting hole in the distributor bracket is only big enough for the bolt that locks it,
what i did to fix this(since adjusting the timing is very important when you go turbo) is i took of the distributor and then took the mounting bracket off of that.
with that done i put the bracket in a vice and using a drill bit that was slightly bigger than the bolt, i elongated the hole to where there was about 1/4 inch of metal left on each side(to retain some strength) and then i put it all back on.
now i can adjust the timing on my car several degrees in each direction.
i will try to get some pics but i dont have a digi cam and im not patient enough to put mods on hold until i can borrow someones camera.
1994 Celica GT4 WRC Edition
@gt4.wrc on Instagram
post Apr 10, 2003 - 6:09 PM
1bwilson
Joined Aug 30, '02
From Maryland
Just get a MSD BTM
-Bryan-
Member of Team 5sfTe
post Apr 10, 2003 - 6:28 PM
97sccelica
Joined Aug 30, '02
From Anaheim, CA
QUOTE (1bwilson @ Apr 10, 2003 - 3:23 PM)
Just get a MSD BTM
-Bryan-
i would love to, but drilling a hole is cheaper. i will probably upgrade the ignition system after the warrenty is over, but also by then i will be contemplating a full gt4 conversion so it all depends on what happens once im in college.
post Apr 10, 2003 - 6:53 PM
west_minist
Joined Oct 27, '02
From Barbados
That is the best thing.
Get an ignition unit w/ timing module.
Well for college students, I guess the distr. is the only solution.
West_Minist
Hydra EMS Dealer & Tuner
Subaru ECUFlash Tuner
http://www.socob.bb
http://xtremeracingtuning.com
Viciously Tuned, Driven Hard
post Apr 10, 2003 - 7:13 PM
Charlie97L
From North Bethesda, MD
Just get a MSD BTM
-Bryan-
that won't work. lance tried to install it and was unable to. i'm considering getting the apexi ITC tho. thanks for the tips man! glad you got it working.
1994 Lexus ES300
1989 Supra Turbo
1990 RHD ST185RC - JDM Spec
post Apr 10, 2003 - 7:47 PM
1bwilson
Joined Aug 30, '02
From Maryland
QUOTE (Charlie97L @ Apr 10, 2003 - 4:27 PM)
Just get a MSD BTM
-Bryan-
Oh thanks for clearing that up. I don't want to mislead people. i hear it ill work fine for the 5sfte project so I just assumed it would help him out also. We'll see if it helps me or not in about 1-2 months.
-Bryan-
Lo-Fi Version Time is now: February 26th, 2025 - 4:31 PM
