Camber kits, CHEAP---- |
Mar 7, 2009 - 1:48 PM |
Enthusiast Joined Sep 29, '08 From miami Currently Offline Reputation: 0 (0%) |
i dropped 3 -3 1/4 and cut springs and it rides like normal(exept for bumps of course killer) and they dont tilt
-------------------- -RELYKS
Mar 7, 2009 - 4:42 PM |
no problem trdproven. The shop said i might need the bolts the next time around when i do alignment. which he said you have to do every 12,000 miles. So i'll be good for a year and a half, if not longer.
Oct 20, 2010 - 8:36 PM |
Enthusiast Joined Jul 19, '04 From Los Angeles, CA Currently Offline Reputation: 2 (100%) |
What I dont understand is how a longer bolt will allow for a greater adjustment. I have too much negative camber (-1.6) and it is causing wearing on the inner tires. What camber kit should I be looking for?
Oct 20, 2010 - 8:39 PM |
Enthusiast Joined Apr 28, '09 From York pa Currently Offline Reputation: 3 (100%) |
eibach
Oct 20, 2010 - 9:45 PM |
Enthusiast Joined Dec 26, '09 From Albuquerque, NM Currently Offline Reputation: 19 (100%) |
June '12 COTM '95 AT200 |
Oct 21, 2010 - 11:44 AM |
Enthusiast Joined Jan 20, '09 From Winnipeg Currently Offline Reputation: 5 (100%) |
Where exactly do these camber bolts go? And how does it help reduce camber?
-------------------- -Protection mode, For when your amp tries to blow its load. 1995 Toyota Celica GTS - Daily Driver 1999 Chevy Cavalier - Winter Beater 1994 Honda Civic CX Hatchback - Dead My Celica! |
Oct 21, 2010 - 1:21 PM |
Enthusiast Joined Oct 7, '09 From Northern kentucky Currently Offline Reputation: 8 (90%) |
the best way i can describe a camber bolt is like this, its a bolt shaped sort of like a pinball flipper, and you adjust it to your liking or the shop will
-------------------- 1996 Toyota Celica Project Mean Green
3RD Gen 3SGTE WRC Edition W/LSD E153 - Love BOOST <3 2001 Solar yellow Lexus IS300 2001 Dodge ram 1500 Off-road edition |
Oct 21, 2010 - 1:50 PM |
So where does it go on the car? i've never really understood them.
I'm lowered on tien s techs 1" in the back and 1.5" in the front. Do I need camber bolts? On the allignment print outThe rear camber was at the msot allowable camber, i think -1.5 or -1.6 -------------------- -Protection mode, For when your amp tries to blow its load. 1995 Toyota Celica GTS - Daily Driver 1999 Chevy Cavalier - Winter Beater 1994 Honda Civic CX Hatchback - Dead My Celica! |
Oct 22, 2010 - 12:59 AM |
it really depends on the shop. hopefully they are honest to you and say then say you need camber bolts when in reality you don't. I got my alignment two years ago with 2.2 inch drop in front and 1.5 in the rear and I bought camber bolts but didn't need them that time. I'm doing alignment in about 3 weeks. So hopefully my lowering springs haven't dropped significantly enough to the point where I'm going to have them install my camber bolts that I bought two years ago. If they do use camber bolts with the alignment, they will charge an extra $20 per wheel or so.
This post has been edited by BonzaiCelica: Oct 22, 2010 - 1:00 AM -------------------- Group buy to replicate Narrow E series transaxle parts
Oct 22, 2010 - 12:03 PM |
Well I dropped mine myself.
And when I did the allignment the printout said that the most allowable negative camber was -1.6, and thats what my car was at, so they didn't need to adjust it. But should I be worried about tire wear or anything like that? -------------------- -Protection mode, For when your amp tries to blow its load. 1995 Toyota Celica GTS - Daily Driver 1999 Chevy Cavalier - Winter Beater 1994 Honda Civic CX Hatchback - Dead My Celica! |
Oct 22, 2010 - 1:09 PM |
Well I dropped mine myself. And when I did the allignment the printout said that the most allowable negative camber was -1.6, and thats what my car was at, so they didn't need to adjust it. But should I be worried about tire wear or anything like that? Cars come from the factory with negative camber. That's probably just the factory specs. -------------------- taking too long to mod since '09
Oct 22, 2010 - 3:00 PM |
alright thanks man
Mar 3, 2013 - 5:22 PM |
Enthusiast Joined Mar 8, '12 From Hanford/Fresno, Ca Currently Offline Reputation: 20 (100%) |
So those crash bolts. Anyone have pics or tell me how they work? Them links are too old and none of them are working out for me. I'm in need of rear camber bolts.
Found these eibach camber bolt for the rear. I just want to know if they will fit my car? I have a st204 with megan coilovers. http://www.raceinspired.com/p-33620-eibach...-1986-2004.aspx This post has been edited by ILoveMySilly97: Mar 3, 2013 - 5:33 PM -------------------- |
Mar 3, 2013 - 6:26 PM |
they will fit
-------------------- 1995 GT::::Diffusing the Situation エキサイティングカーレーシングチーム! march 2010 COTM : 6GC feature 2014 : january 2015-2016-2018 COTM |
Mar 3, 2013 - 7:37 PM |
That's good to know. Im tired of the extreme camber look.
Mar 3, 2013 - 7:52 PM |
i bet your tires are tired as well
Mar 3, 2013 - 7:53 PM |
Enthusiast Joined Apr 17, '10 From Maitland, NSW Currently Offline Reputation: 3 (100%) |
^they look identical to the ones I have, you spin the bolt when you tighten it, and it will push the hub out, or in, depending what you want.
Just make sure if YOU do it, tighten the bolts as much as you can. I've gone driving afterwards and it's popped back into its original place, and had negative camber again. -------------------- |
Mar 3, 2013 - 11:27 PM |
i bet your tires are tired as well Yes they are. Lol. ^they look identical to the ones I have, you spin the bolt when you tighten it, and it will push the hub out, or in, depending what you want. Just make sure if YOU do it, tighten the bolts as much as you can. I've gone driving afterwards and it's popped back into its original place, and had negative camber again. That's something I'm expecting. I'm pretty sure it's just a skinnier bolt with a flap that rotates around. Pushing the top of the strut outward or inward. Which makes the negative or positive camber as desired. -------------------- |
Lo-Fi Version | Time is now: January 9th, 2025 - 4:21 PM |
