few things need fixed how?? |
Apr 16, 2005 - 4:00 PM |
Enthusiast Joined Apr 14, '05 From garfield hts. O-HI-O Currently Offline Reputation: 0 (0%) |
well i noticed today when ig ot my celica that the shoft boot need replaced so how do i get that out and what one will fit in there i dont wana have to order somethin i wana get it from the part store 2 marro. also how do i get my stock head unit out?? i have the harnesses for the new head unit, i think?? lol they were given to me witht he car. there 2 and ones bigger then the other how do i know whats for what?? and last my key on the drivers side door doesnt work the key goes in but it wont turn to un ock it, how do i fix this?? thanks
Apr 16, 2005 - 5:10 PM |
Enthusiast Joined Apr 4, '05 Currently Offline Reputation: 0 (0%) |
1st; Shift Boot -- Take off the plastic surround around the boot, turn it over you will see two long metal clips, remove them, remove old boot, replace boot, replace metal clips.
2nd; Radio, remove the plastic bezel around radio,a/c,vents... behind that is your stock radio remove the 4 screws, pull out old radio. 3rd; Key on door, remove door panel , make sure window is rolled up, look up inside door you will see the key, remove the metal bar connected to the door lock, remove the clip holding door lock, replace door lock. |
Apr 16, 2005 - 8:58 PM |
Enthusiast Joined Feb 25, '04 From Fairfield, CA Currently Offline Reputation: 0 (0%) |
I talked to the dealer about mine, and they told me it would be cheaper to take my boot to an upholstery shop and have them sew one up using the OEM hardware on the worn out one. Instead I bought a cheapo one from jujeracing.com (they claim to use OEM mounting hardware), but it was a piece of crap that I had to make my own mounting hardware for out of bent wire. If I were to do it again, I'd have gone with the upholstery shop.
Good luck with the other two things. |
Apr 17, 2005 - 6:12 AM |
Apr 17, 2005 - 9:46 AM |
QUOTE(Dm_Vinny @ Apr 17, 2005 - 4:12 AM) I bought this; http://www.jcwhitney.com/autoparts/Product...0002742/c-10101 [right][snapback]272606[/snapback][/right] But it doesn't have the OEM mounting hardware on it, so you're stuck making your own, just like I had to... |
Apr 17, 2005 - 11:27 AM |
well for the stereo install i got the 2 harnesses, and hooked mine up and it powered up but no sound out of the speakers, so i took it off put the stock one back on and its fine. i dont think theres an amp and they guy i bought the car from had his cd player in there and it worked fine with the harnesse. what could be wrong?? like i said i get power just no noise
Apr 17, 2005 - 11:29 AM |
also where can i get s hift boot that fits the stock one?? all the ones i have seen are round and have elastic at the bottom so i dont think it would work
Lo-Fi Version | Time is now: November 24th, 2024 - 1:28 PM |
