> Aftermarket rotors, suggestions?
post Apr 18, 2005 - 3:09 PM
Akimbo
Joined Jun 30, '03
From O-town, FL
I'm looking to buy some aftermarket rotors. Anyone know where to find good ones? Maybe some Brembo ones?
- Ryan
aim: rkgreen04
post Apr 18, 2005 - 3:17 PM
shin
Joined Aug 21, '04
From New York City
cross drilled? slotted? cross drilled & slotted? or stock replacements?
~*MuH NeW RiDe*~
post Apr 18, 2005 - 5:29 PM
got a set of brembo slotted if your interested
post Apr 18, 2005 - 8:25 PM
LewFX
Joined Jan 28, '05
From Redondo Beach, CA
how much for the brembo slotted?
post Apr 18, 2005 - 8:26 PM
Akimbo
Joined Jun 30, '03
From O-town, FL
Looking to go with some good looking, good braking, slotted/drilled, or any combination thereof. Playr, are they front and back for a GT?
- Ryan
aim: rkgreen04
post Apr 18, 2005 - 9:35 PM
GT4WRC
Joined Mar 17, '05
From Auckland, New Zealand
Beware x drilled rotors. They were originally designed for race cars to reduce unsprung weight. Due to the holes, they are prone to cracking, especially if the holes are drilled after the casting has been done - often the case for most aftermarket applications.
Slotted rotors are a thow back to days when asbestos was used in pads. Due to a build of of gases as a result of the pad resins heating up. The grooves allowed the gas to 'escape' as it would usually create a 'barrier' between pad and rotor which lead to brake fade. Grooved rotors do work well, but do tend to acellerate pad wear.
Gary
1994 ST205 Celica GT-FOUR Group A WRC - running in new engine
1993 Rover 220 GTi tarmac rally car (under construction) 3SGE power here we come....
GT-Four spec list
post Apr 18, 2005 - 9:44 PM
BLINKYxMUNKEY
Joined Nov 12, '03
From Crestview, Florida
ive heard good things about www.irotors.com
FlickR
post Apr 18, 2005 - 10:05 PM
ghostdog
From ny to philly
all true and good points. but you are forgetting the most important part .. they look cool rolleyes.gif
QUOTE(GT4WRC @ Apr 18, 2005 - 10:35 PM)
Gary
[right][snapback]273586[/snapback][/right]
post Apr 18, 2005 - 11:14 PM
Akimbo
Joined Jun 30, '03
From O-town, FL
just need something to improve braking...
- Ryan
aim: rkgreen04
post Apr 19, 2005 - 5:22 AM
GT4WRC
Joined Mar 17, '05
QUOTE(Akimbo @ Apr 18, 2005 - 11:14 PM)
[right][snapback]273656[/snapback][/right]
In that case, stay with stock rotors and get some decent aftermarket pads. I'd recommend Mintex 1144 pads for normal road use or 1155s if you want to push the car a bit harder. And also put in some decent brake fluid. Standard road use stuff like DOT 4 etc isn';t up to much when you start getting serious heat in the brakes as it has a relatively low boiling point. I personally use Elf HTX brake fluid which I also use in my rally car. Not had brake fade as a result of boiling fluid yet - and the car does get pushed hard. See the vids I posted a while back wink.gif
Gary
GT-Four spec list
post Apr 20, 2005 - 1:20 PM
Akimbo
Joined Jun 30, '03
From O-town, FL
I dunno what to get...
http://cgi.ebay.com/ebaymotors/ws/eBayISAP...7967971487&rd=1
http://cgi.ebay.com/ebaymotors/ws/eBayISAP...ssPageName=WDVW
- Ryan
aim: rkgreen04
post Apr 20, 2005 - 2:52 PM
QUOTE(playr158 @ Apr 18, 2005 - 3:29 PM)
[right][snapback]273416[/snapback][/right]
Brembo doesn't make slotted rotors for our cars.
Anyway,
I'd get the OEM replacment Brembos from NopiOnline.com. They've got good pricing and they're actual Brembo rotors, and they're not slotted or cross-drilled so you'll have longer brake pad life and better braking performance(until the rotors get too hot, at which point one of the cross-drilled or slotted rotors may outperform an OEM replacement due to better thermal cooling...not sure though.)
post Apr 20, 2005 - 3:00 PM
FallenHero
Joined Dec 26, '02
From Alabama
I ordered mine from chadrotors@hotmail.com
I got them quick, he answered all my questions, everything went great.
E-mail him with what you have and what you want, and he will get you a price.
Jon
post Apr 20, 2005 - 5:04 PM
GT4WRC
Joined Mar 17, '05
Take it or leave it, but my advice still stands. Do not buy x drilled rotors for street cars (forget the likes of Porsche as the holes are put in at the time of casting and use a higher quality material).
Also, thermal cooling is not always better on x drilled either as there is physically less surface area due to the holes.
I do realise that there are many people out there who have x drilled, but at the same time I have seen the results of a vicious heat cycle on these types of rotors and the resulting cracks. And how many people physically inspect their rotors for damage?
Save your dosh and buy OEM rotors and then use the $ saved to buy some decent pads.
Gary
GT-Four spec list
post Apr 20, 2005 - 9:36 PM
Jdog1385
Joined Apr 14, '03
From Long Island, N.Y.
www.irotors.com
your best bet. i love them
post Apr 20, 2005 - 11:40 PM
Akimbo
Joined Jun 30, '03
From O-town, FL
I can't find Celica ones?
- Ryan
aim: rkgreen04
post Apr 21, 2005 - 12:44 AM
Jdog1385
Joined Apr 14, '03
http://www.irotors.com/products/20-3.shtml
they're on the list. its about 230 for front and back.
post Apr 21, 2005 - 7:27 PM
juBz86
Joined Aug 18, '04
From NJ
ok wat if i only get slotted?? this will lower the life of my pads correct?
post Apr 23, 2005 - 12:05 AM
dustin15brown
Joined Aug 17, '03
From Bloomington, Indiana
I love mine from nopi.com they're the #1 cross drilled and slotted.. Not too expensive either
post Apr 23, 2005 - 2:50 PM
GT4WRC
Joined Mar 17, '05
QUOTE(juBz86 @ Apr 21, 2005 - 7:27 PM)
[right][snapback]275837[/snapback][/right]
Yes. You will also need to remove the rotors occasionally to clean out the grooves as they 'fill' up with hardened brake dust, effectively reducing their efficiency. Small flat bladed screwdriver is good for doing that.
Gary
GT-Four spec list
Lo-Fi Version Time is now: February 22nd, 2025 - 2:50 PM
