![]() Enthusiast ![]() Joined Nov 4, '04 From Ireland Currently Offline Reputation: 0 (0%) ![]() |
are the ones from irotor.com oem's replacement or drilled/grooved?
-------------------- arospeeds suck ass!!!
![]() Enthusiast ![]() ![]() ![]() Joined May 5, '05 From New-Brunswick Canada Currently Offline Reputation: 3 (100%) ![]() |
This is quite a interesting topic, from what i read it is true that drilling the rotors can make them suspectible to cracking but i can't seem to find any evidence of x drilled rotors cracking on street cars
-------------------- ----------------------6GC's FIRST V6----------------------
![]() JDM 96 MR2-T Faster - 94 Celica GT 3MZFE Funner - 99 Rav 4 AWD Handy |
well you don't drill your own rotors
you need to buy rotors that were design'd and built with holes in it like irotors, or number #1 |
Enthusiast ![]() Joined May 11, '05 From Bristol, UK Currently Offline Reputation: 0 (0%) ![]() |
Black Diamond do a different type of rotor for all gen6, grooved, drilled or both good price too!
![]() Enthusiast ![]() Joined Apr 6, '05 From homosassa,florida Currently Offline Reputation: 0 (0%) ![]() |
go with irotors ive had mine for a year and still work like theyre brand new
also get those thermo cooled pads also another awesome mod i can stop on a dime. -------------------- FOR 21 YEARS I DEALT WITH THE RAIN,
ONLY TO FIND OUT THAT I COULD STOP THE PAIN, SO NOWITZON!!! |
![]() Enthusiast ![]() ![]() Joined Apr 23, '04 From WA Currently Offline Reputation: 3 (100%) ![]() |
would the fronts rotors for the gt work on the st? (on the front ofcourse)
NO
only 7th gen assembly (rotor, caliper) will work on st fronts GT can only be used to replace the rear on the ST in a DRUM to DISK swap |
![]() Administrator ![]() ![]() ![]() ![]() ![]() Joined Aug 23, '02 From Seattle, WA Currently Offline Reputation: 14 (100%) ![]() |
QUOTE(playr158 @ May 14, 2005 - 9:24 AM) NO only 7th gen assembly (rotor, caliper) will work on st fronts GT can only be used to replace the rear on the ST in a DRUM to DISK swap [right][snapback]286862[/snapback][/right] What are you talking about? The GT rotor and caliper will work on the ST front brakes. Please stop posting random information if you don't know what you're talking about. -------------------- New Toyota project coming soon...
QUOTE(playr158 @ May 10, 2005 - 4:48 PM) well you don't drill your own rotors you need to buy rotors that were design'd and built with holes in it like irotors, or number #1 [right][snapback]285185[/snapback][/right] lol, I wouldn't do that with my own rotors I should have mentioned that i was refering to, for example, a set of oem replacement brembo rotors that were drilled after they were manifacture. Some suppliers buy them and gets them crossed drilled with a CNC machine. Now knowing that drilling the rotors can make them more suspectible to cracking when they are used excessively (like at a track), is there any evidence of it ever happening on normal street cars that the driver got a little too ruff on the brakes on one occasion? -------------------- ----------------------6GC's FIRST V6----------------------
QUOTE(Coomer @ May 14, 2005 - 11:29 AM) QUOTE(playr158 @ May 14, 2005 - 9:24 AM) NO only 7th gen assembly (rotor, caliper) will work on st fronts GT can only be used to replace the rear on the ST in a DRUM to DISK swap [right][snapback]286862[/snapback][/right] What are you talking about? The GT rotor and caliper will work on the ST front brakes. Please stop posting random information if you don't know what you're talking about. [right][snapback]286864[/snapback][/right] coomer don't be a douche i know what i'm talking about and if you would read his question he said "ROTORS" from a gt and keep the stock ST calipers as calipers were never mentioned in his question "would the fronts rotors for the gt work on the st?" evidence- Wearever YH145009 Front; ST Model Wearever YH145004 Front; GT Models thank you i rest my case coomer next time look up part numbers Gt front rotor is different then ST front rotor and will not work unless the caliper is changed too ( GT CALIPER Cardone 171777 Reman.; Loaded; Left; OE Metal Piston Lifetime Limited Warranty ) (ST CALIPER Cardone 191777 Reman.; Unloaded; Left; OE Metal Piston Lifetime Limited Warranty) so "Please stop posting random information if you don't know what you're talking about." thank you |
Ok Daniel, I'm well aware that the GT rotors alone will not fit on the front of the ST.
However, you mention the following: QUOTE only 7th gen assembly (rotor, caliper) will work on st fronts This is just not true. The Seventh gen. Celica assembly is NOT the only front brake setup that will work on the ST. The sixth gen. Celica GT's assembly will also work. Furthermore, you mention this: QUOTE GT can only be used to replace the rear on the ST This implies that the GT front setup cannot be used on the front of the ST. Maybe I should've re-worded what I said to say "Don't post confusing posts that imply incorrect information." The fact is though, that you often post incorrect information, and lots of knowledgable people are very sick of it. And if you continue to insult me on top of posting consistently wrong information, then you'll find yourself warned shortly. -------------------- New Toyota project coming soon...
so you can inssult members but we can't do the same?
i see well i'll save pickering for off a decent thread i do edit may saying as the info is right except a picky word "only" i retract that word you "could" put a entire gt front assembly on an st and you "could" but an entire 7th gen front assembly on an st answer to question originally asked which i did answer CORRECTLY "gt rotors do not fit on a st" order st rotors for an st and gt rotors for an st unless you want to get into a "swap' |
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Jan 8, '04 From LA Currently Offline Reputation: 0 (0%) ![]() |
Playr, I've smacked you down before for your constant posting of misinformation regarding brakes and rotors in general. it's fairly obvious that you have no friggin clue about any of these items. Don't make me drag that thread out of the deep dark depths.
Enthusiast ![]() ![]() ![]() Joined Jul 27, '04 From phoenix az Currently Offline Reputation: 0 (0%) ![]() |
lol...
QUOTE(shid @ May 17, 2005 - 10:21 PM) Playr, I've smacked you down before for your constant posting of misinformation regarding brakes and rotors in general. it's fairly obvious that you have no friggin clue about any of these items. Don't make me drag that thread out of the deep dark depths. [right][snapback]288286[/snapback][/right] dude thats bs but watever screw this |
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Dec 26, '02 From Alabama Currently Offline Reputation: 2 (100%) ![]() |
Can you feel the love in here?
![]() Enthusiast ![]() ![]() ![]() Joined May 24, '03 From Milton, Delaware Currently Offline Reputation: 0 (0%) ![]() |
<3?
-------------------- AIM : FAQdaWorld
so for best braking setup for an st is to replace front assebly with 7th gen (and then later on put aftermarket rotors) and replace the whole break assembly in the rear with gt (6th gen) (and then later on put aftermarket rotors)
i am sorrie i am a noob with brakeing systems thanx in advance for help |
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Oct 13, '02 From Blairstown, New Jersey Currently Offline Reputation: 6 (100%) ![]() |
I'll try to help you out a little.
![]() However, I want to advise you that they list the ST as having a front and rear disc brake combo available, which doesn't make sense since the ST uses a rear drum (unless its a upgraded drum setup??) Before you order that package I would call them and talk to a representitave directly so you dont get the wrong product. What I would tell you to do, is that depending on your needs you should first look into the front rotor setup for the ST, then if you want to go further you can acquire the caliper setup from the rear of a 6th generation GT and use the rear rotors found on irotors along with the ST fronts. Good luck, and if you have any questions just ask. ![]() -------------------- 3rd gen ST205 3SGTE - Alive and boosting. |
![]() Enthusiast ![]() ![]() ![]() ![]() Joined Dec 16, '02 From Cincinnati, Ohio Currently Offline Reputation: 0 (0%) ![]() |
From reading previous topics, it doesn't really matter what you want to put on the front. 5th, 6th or 7th gen gt's . The difference in size is minimal and I doubt that you would be doing some serious braking to really need the difference in size, So it comes down to cost. I think you'd be better off buying front gt calipers form a 6th gen.(might be cheaper and easier to find) And Rotors From irotors if you are looking for something nice looking. If not go with stock replacements.
As for rear, I have my rear setups from 5th gen celica. It works fine. I also have irotors on the rear. I like em, and there is a difference in braking from drum to disc. Go with ceramic pads, I like 'em, but this isn't what I like or what anyone else likes, its what you like. This post has been edited by Jeremy1210: May 24, 2005 - 8:46 AM |
Lo-Fi Version | Time is now: February 22nd, 2025 - 2:47 PM |
