> Best clutch for the 5sfe undergoing 3sgte swap, I already did the search, couldn't find
post Apr 20, 2005 - 2:11 AM
CelicaSTX02
Joined Sep 24, '02
From North Carolina
Hey guys, don't flame me cause I already did the search thing. Just couldn't find exactly the information I needed.
Anyways, I have a 1997 GT manual celica now. In 3 months when school is over, I am doing the 3sgte swap......I already have the motor.
I want to keep the car for a while, and all I am doing is swapping in the motor and put on a blow-off valve.
What is the most efficient clutch if I continue to use the 5sfe tranny for the swap??
I know performance clutches isn't very good on the tranny, so should I just stick to the oem?? Is the exedy an oem clutch?? What clutch would you recommend me using?? What kind of clutch do you guys use??
post Apr 20, 2005 - 7:51 AM
ZoomZoom
Joined Apr 7, '04
From Toronto
I suggest to go with oem clutch if you're using the 5sfe tranny.
Thats what I used on mine and it still pretty good, but I want more traction so im working on the mr2 tranny swap this spring.
hope this helps you.
Ciao...
post Apr 20, 2005 - 9:28 AM
jgreening
Joined Jan 17, '04
From Illinois
If you are not going to mod the car, I would use a stock clutch. You will need a hybrid clutch if you are going to use the GT tranny. Do a search there is a ton of information on it. If your goals exceed 200whp, I would get an aftermarket clutch of somekind. I recommend Clutchmasters and Spec. up to Stage 3 for stock-like pedal feel.
post Apr 20, 2005 - 9:33 AM
I have over 200whp and using the stock clutch. As of right now its not slipping, surprisingly.
post Apr 20, 2005 - 10:34 AM
if you use and mr2 tranny, then the stock clutch will work fine, because its made to handle the power that and mr2 makes. if you keep your gt tranny, the stock clutch will not last long. my act Street Disk (oem type of holding power) did ok for about 6 months but started sliping as soon as i started running more then 10psi of boost.
i would recomend a spec stage 2 or stage 3, or clutchmasters stage 3.
Lo-Fi Version Time is now: November 29th, 2024 - 4:46 AM
