> hole in firewall, where to drill?
post Apr 21, 2005 - 3:30 PM
orvillescelica
I need to run a power line directly from my battery to the interior. I am just wondering if you guys have any tips on where the best place is to drill a small hole in the firewall to run wire through.
If drilling isnt the best solution, then what did you guys do? Im planning on running two 8 gauge wires and thats it.
post Apr 21, 2005 - 3:36 PM
I drilled right behind my pedals and ran wire through there. I can take a pic for you if you'd like.
post Apr 21, 2005 - 3:46 PM
Consynx
Joined Dec 25, '02
From Pittsburgh/Clairton, PA
i did pedals as well when i wired, but i was shown a new spot...
going through the fender well and coming in by all the fuses + plugs.
post Apr 21, 2005 - 3:48 PM
Well, I might pull off my fenders tonight...I'll look for a way to run it through there.
post Apr 21, 2005 - 10:51 PM
orvillescelica
thanks guys for your help... can you give me any more info on going through the fender well??
post Apr 22, 2005 - 9:20 PM
orvillescelica
OK, im pretty much completely worthless at this point.
I went to go drill a hole under the pedals like you guys suggested, but upon looking down there and trying to compare it with the other side of the firewall, im scared that ill drill and hit something.
Is there a safe place to drill??
post Apr 22, 2005 - 10:13 PM
I'll get pics of where you could probably run wire through the fender. I'll be back in 20 minutes or so with them. smile.gif
post Apr 22, 2005 - 10:35 PM
post Apr 23, 2005 - 12:59 AM
pnoywitmustrdsau...
Joined Mar 28, '05
From California
depends, you running a power for an amp, i ran 4 gauge to an amp, i drilled the hole, directly in front of the brake, but high enough not to get it caught when stepping on the pedals, so when you do make the hole just just under the brake master cylinder you can make the hole up to a 1/2 inch wide but 4 gauge, 3/4 will do, and always supply a grommet
post Apr 23, 2005 - 1:28 PM
Kadett
Joined Mar 17, '05
From The Netherlands
I found a hole that already excisted from the start. On the right side of the car. Just plugged the rubber piece covering it.
Dont u guys have a hole @ the passenger side of the car in the firewall?
post Apr 23, 2005 - 9:02 PM
Seth6Gen
Joined Sep 22, '02
From Mammoth CA
you can also do this, its real easy...
you can just poke it through a little rubber housing... aint no thang.
This post has been edited by Seth6Gen: Apr 23, 2005 - 9:02 PM
post May 20, 2005 - 9:43 PM
DamDirtyApes
Joined Apr 22, '04
From Rhode Island
there is a pre made hole in the celicas driver side. why not just use that
post May 21, 2005 - 6:59 AM
raz128
Joined Oct 29, '03
From Gosport, Hampshire, UK
There should be a rectangular rubber grommet in the firewall (well, there is on my UK spec right-hand drive Celi). There was more than enough space to easily poke my gauge 4 power cable through without any hassle.
Lo-Fi Version Time is now: February 21st, 2025 - 1:22 PM
