4 Pages V  < 1 2 3 4 >
> 4agze pistons ina 7afe???, will they fit?
post Apr 23, 2005 - 10:05 AM
you pulled those numbers from where?
post Apr 23, 2005 - 6:49 PM
nik
Joined Sep 30, '02
QUOTE(raven_101 @ Apr 23, 2005 - 2:06 AM)
Using 4AGZE pistons in a 7AFE will give you 11:1 compression. However, if you swap a 4AGE head on there, you'll be all set, 8.5:1 or 8.9:1 depending on which version you use. Plus the GE head is better anyway.
[right][snapback]276757[/snapback][/right]
do you have any info to back that up i know edo's comp rose but what proof do you have on the 4ag head ??
post Apr 23, 2005 - 6:51 PM
exactly ^^
post Apr 23, 2005 - 11:14 PM
Dr_Tweak
Joined Mar 31, '04
From Summerville, SC
The difference in compression between the two engines is because of the head, so even using 4AGZE pistons ends up with high compression.
I haven't done this personally but I know several people that are running 7AGEs with 4AGZE pistons.
-Doc
Click here to see my swaps
drtweak@phoenixtuning.com
post Apr 24, 2005 - 2:15 PM
doGGy
Joined Oct 28, '02
From Europe, Lithuania
WRONG.
The diffetrence is not only in heads, the difference is in pistons - 7A pistons are DISHED, GZE almost flat, with the dished valve places. Pistons are the same height, but the difference is in these 10 cc that 7A piston Dish has.
QUOTE(raven_101 @ Apr 23, 2005 - 9:14 PM)
-Doc
[right][snapback]277046[/snapback][/right]
<<<<<< DCw / JDMart >>>>>>>
post Apr 24, 2005 - 3:36 PM
Dr_Tweak
Joined Mar 31, '04
QUOTE(doGGy @ Apr 24, 2005 - 7:15 PM)
WRONG.
[right][snapback]277244[/snapback][/right]
Think about what you're saying. If you swap the GZE pistons in, the compression goes up. Why is this not the case when you use the GE head? Because of the combustion chamber. Yes, the piston of the 7AFE is dished, which is part of it (I should have added that), but we're talking about using GZE pistons in a 7AFE.
When you use 4AGZE pistons in a 7AFE with a 7AFE head, the compression goes up.
When you use 4AGZE pistons in a 7AFE with a 4AGE head, the compression goes down.
Why? Because the head is different. End of story.
I wonder what the compresssion ratio would be in a 4AGE using 7AFE pistons?!
post Apr 24, 2005 - 3:39 PM
doGGy
Joined Oct 28, '02
here im talking about 7AFE with GZE pistons. Not the 7AGE. And CR with GZE pistons in 7AFE will be 10.8 if not using oversized pistons. With 82 Bore, and GZE pistons, the CR is at 11.02. This been proved on Edos car. As on stock 7A, you can count the CR, it will be 10.8 without overboring.
As for head swap, yes, the combusion chamber on GE head is bigger then on 7A, so the CR will drop noticibly.
QUOTE(raven_101 @ Apr 24, 2005 - 1:36 PM)
WRONG.
[right][snapback]277274[/snapback][/right]
post Apr 24, 2005 - 7:33 PM
Kwanza26
Joined Dec 27, '03
From Nor Cal
QUOTE(raven_101 @ Apr 24, 2005 - 8:36 PM)
It's equally the piston and the head. The older FE head designs had part of the combustion chamber carved into the piston top. Likewise, compression increase with the 4AGZ pistons is both because of the pistons and the stroke ratio. The 7A has a larger stroke ratio and that adds to the compression increase along with the flat topp-ed pistons. In a 7AGE, things will look more similar to the 4AGZE as far as compression goes, but it'll still be higher. I would estimate around 8:5 (7AGE) with the 8:0:1 4AGZE pistons and around 9:2 to 9:3 with the 8:9 pistons...
Very low...
post Apr 24, 2005 - 9:07 PM
ok basically all we need to know is
4agze pistons at a 82mm bore
with a 7afe motor (no headswap)
post Apr 24, 2005 - 9:14 PM
StreetRacing10PS...
Joined Oct 10, '04
From New Jersey
all i really wanna know is what do i have to do to lower my compression with forged 4age pistons in my 7aFE. is a thicker head gasket all i need?
post Apr 24, 2005 - 9:47 PM
Kwanza26
Joined Dec 27, '03
From Nor Cal
It'll raise your compression to higher than stock. Even with a thick headgasket, you're still looking at compression at stock levels... so it would really serve no purpose. One might think strength will increase... but that all comes down to tuning. 4AGZ pistons will be a bigger tuning hazard because relative compression increase will be mostly unknown, but expected in the high 10's... 4AGZE pistons is NOT a good way to go if you're looking to boost a 7AFE... Sure they're stronger pistons... but so what if tuning is gonna be that much harder...
post Apr 24, 2005 - 9:52 PM
StreetRacing10PS...
Joined Oct 10, '04
From New Jersey
ok, so i get my turbo probly some time this week or when ever it gets mailed. and ill b runing around 8 PSI. but i wanna get the boost up to around 15+PSI but for that to b safe i would have to run forged internals, but if 4age pistons raise my compression to over 10:1 then it wont be safe on the engine. so is it worth getting the forged pistons or should i leave it stock??
post Apr 24, 2005 - 9:57 PM
you can boost a 10:1 cr fine at 10-15psi you just have to make sure that your emanager is tunned
but i'm goin to run
82mm bore with a 2mm headgasket
ported and polished head
shot peen'd rods
3 angle valve job
4agze pistons
imo don't use stock pistons if you wanna shoot for 10psi and over
post Apr 24, 2005 - 10:16 PM
StreetRacing10PS...
Joined Oct 10, '04
From New Jersey
i no, i posted a pic in the off topic forum i think it was a few weeks ago of my friends eclipse that blew a piston runnin 13 PSI on his stock internals....not a pretty site..... too much boost
This post has been edited by StreetRacing10PSI: Apr 24, 2005 - 10:16 PM
post Apr 25, 2005 - 2:39 AM
Kwanza26
Joined Dec 27, '03
From Nor Cal
QUOTE(playr158 @ Apr 25, 2005 - 2:57 AM)
but i'm goin to run
shot peen'd rods
3 angle valve job
4agze pistons
[right][snapback]277483[/snapback][/right]
why not use stock pistons? Your logic sometimes is just totally wrong. Even forged, because the compression is significantly higher, the heat will be significantly higher, putting just as much, if not more stress on the 4AGZ pistons as would a stock 7A with stock pistons... In the end... it's all about tuning.
You keep listing your little list of "soon to be" modifications... but I'm still not convinced you know what they actually do to the motor.
In the end, IMO, it's really not worth it to go through the trouble of installing 4AGZE pistons. If you must have pistons... get proper ones. Short cuts is what almost always kills custom turbo builds.
I'll still say though... if you're looking for 15 psi+... you can't look to do it cheap.
post Apr 25, 2005 - 3:03 AM
Dr_Tweak
Joined Mar 31, '04
The answer to your question is in this thread. But to lay it right out, it's like this:
If you want 15 psi, you have two options.
1. Do a 4AGE head swap and use the 4AGZE 8:1 pistons which will give you about 8.5:1 CR
2. Get custom forged low compression pistons. Have a look at http://www.importperformanceparts.net/ they have a complete 7AFE rebuild kit with ROSS/Wiseco forged pistons in any compression ratio you want for only $889... that's a sweet deal.
-Dr Tweak
*edit* Oh and I forgot: Never ever ever ever use a thicker head gasket to lower your compression. By doing that, you eliminate the quench (squish) area in the combustion chamber which will increase combustion temperatures and cause massive detonation and preignition problems. Worse than if you had left it at stock compression.
This post has been edited by raven_101: Apr 25, 2005 - 3:07 AM
post Apr 25, 2005 - 7:18 AM
well then thank you for the piston link
i knew goin to wit the thickerheadgasket always isn't a best way to do but hey its not like anyone has gotten the 7afte to the levels like these
and ha if i can get the custom compression pistons then i'm happier smile.gif
post Apr 25, 2005 - 7:20 AM
oh and just so we get the line down
i refuse to swap heads or my motor
so give me the best info for a straight up 7afe
cause its goin to be an original motor project
post Apr 28, 2005 - 10:44 AM
nik
Joined Sep 30, '02
QUOTE(playr158 @ Apr 24, 2005 - 7:57 PM)
but i'm goin to run
shot peen'd rods
3 angle valve job
4agze pistons
i wouldnt use stock rods for 15psi even if they are shot peend
post Apr 28, 2005 - 10:46 AM
nik
Joined Sep 30, '02
QUOTE(playr158 @ Apr 25, 2005 - 5:20 AM)
[right][snapback]277657[/snapback][/right]
with the set up you are going with heat soak is a big factor because of the head design so the longer you run the less power
Lo-Fi Version Time is now: December 4th, 2024 - 2:55 PM
