4agze pistons ina 7afe???, will they fit? |
Apr 28, 2005 - 2:30 PM |
well then i better make sure i have an aluminum radiator with good coolant and good fans
Apr 28, 2005 - 2:35 PM |
Enthusiast Joined Sep 30, '02 From Washington Spokane / Coeur D' Alene Idaho Currently Offline Reputation: 11 (100%) |
QUOTE(playr158 @ Apr 28, 2005 - 12:30 PM) well then i better make sure i have an aluminum radiator with good coolant and good fans [right][snapback]279583[/snapback][/right] i'm still looking for a new rad i might do a honda race half radiator thats like 5 inch deep not sure yet -------------------- yea your 3sgte is cool but ill stick to my 7agte
Apr 28, 2005 - 2:44 PM |
i'm not a big fan of half rads i'd rather run a skinnier full rad....
Apr 28, 2005 - 3:08 PM |
QUOTE(playr158 @ Apr 28, 2005 - 12:44 PM) i'm not a big fan of half rads i'd rather run a skinnier full rad.... [right][snapback]279591[/snapback][/right] i would like a full length one but it might come down to room if i have the room i'll go full if i dont half will do it -------------------- yea your 3sgte is cool but ill stick to my 7agte
Apr 28, 2005 - 6:26 PM |
i would say that the invader front we're both using is large enough to modify and runa full radiator mounted inside of it like infront of the heater core but behind the crash bar? maybe its possible
and makes more room |
Apr 28, 2005 - 11:14 PM |
Enthusiast Joined Feb 7, '05 From Fresno, CA Currently Offline Reputation: 0 (0%) |
OK I read through the post and we have seemed to have found a good custom piston to have stronger internals but what about forged rods where can we get those?
Apr 29, 2005 - 8:36 AM |
already been convered
you have two options low boosting---stock rods shot peen'd high boosting (10psi plus) CUSTOM |
May 1, 2005 - 11:40 PM |
How much would the pistons and rods run?
May 2, 2005 - 12:23 AM |
QUOTE(94ST2 @ May 2, 2005 - 4:40 AM) How much would the pistons and rods run? [right][snapback]281186[/snapback][/right] quite a bit... on average... around 600 bucks for custom pistons and 600 for rods... -------------------- "It's ok to be naked girl... I'm an artist!"
May 2, 2005 - 12:28 AM |
Yeah I was figuring around that much thanks.
May 2, 2005 - 9:07 AM |
QUOTE(playr158 @ Apr 28, 2005 - 4:26 PM) i would say that the invader front we're both using is large enough to modify and runa full radiator mounted inside of it like infront of the heater core but behind the crash bar? maybe its possible and makes more room [right][snapback]279684[/snapback][/right] yeah i looked at that i just have to get some measurements and see what rad will fit plus i need the outlet and inlet on the passanger side or atleast the top one -------------------- yea your 3sgte is cool but ill stick to my 7agte
May 2, 2005 - 11:06 AM |
QUOTE(nik @ May 2, 2005 - 9:07 AM) QUOTE(playr158 @ Apr 28, 2005 - 4:26 PM) i would say that the invader front we're both using is large enough to modify and runa full radiator mounted inside of it like infront of the heater core but behind the crash bar? maybe its possible and makes more room [right][snapback]279684[/snapback][/right] yeah i looked at that i just have to get some measurements and see what rad will fit plus i need the outlet and inlet on the passanger side or atleast the top one [right][snapback]281284[/snapback][/right] oh you would have to use the 4age rad then huh? well even if its not on the right side you can go down to advancedauto or sumthing and pick up some extra hose thats just a bit longer and extend it.....that shouldn't effect anything... |
May 2, 2005 - 11:50 AM |
i just want it to look clean and not have 4' of hose in there
May 2, 2005 - 12:36 PM |
well you shouldnt see most of the hose since it will be inside the bumper
just the 1' that goes from the head/wp/block or what not to the bumper enterance you keep the rest inside the bumper so you can't see it |
Oct 29, 2005 - 1:57 AM |
Enthusiast Joined Oct 27, '05 Currently Offline Reputation: 0 (0%) |
bro's,
so may i assume that if i wanna build a high comp NA engine on 7aGE, which piston should i go for? |
Oct 29, 2005 - 2:07 AM |
7age? your doing a head swap or a 7afe?
if your building a 7age then you HAVE to use 4age high compression pistons if your using a 7afe....then normal 4age regular compression pistons will do just fine...you'll end up around 11:1cr |
Oct 29, 2005 - 11:30 PM |
Tks dude.
Well engine has been open apart to check on condition now. most likely will go for a head swap. my mech was saying why not 20V but i don't really like the idea of having serious power comes only at 5500rpm later.. As for FE head, i felt its very "lazy" in revving |
Oct 30, 2005 - 2:59 PM |
cause its an econobox head
Oct 30, 2005 - 3:35 PM |
Enthusiast Joined Oct 28, '02 From Europe, Lithuania Currently Offline Reputation: 8 (100%) |
K, time to write it again.
As i know for now im the only one who TRYED TO PUT GZE pistons in the 7A. First: EVERYTHING FITS LIKE IT SHOULD BE. !!!!!!BUT!!!!!! I used GZE (or GE)20mm wrist pin pistons. The wrist pin of the GZE is the same diameter as the 7A pins. BUT wrist pins of the GZE (or GE) pistons are FULL FLOATING, 7A pins are PRESS FITED. Difference is what 4AGZE rods have coper/bronze insert in the top of the rod, AND wrist pins float in it, and there is the oiling chanel in the rods for oiling the pins. 7A rods DO NOT have pin insert, DO not HAVE oiling cuz pin is pressure fitted and DOESNT move in the rod pistons move on the pin. Then puting GZE (or GE) pistons MIND one thing: GZE pistons pins are full floating, so the restriction of the pin floting is in the piston. Then you press fit the GZE pins in the 7A rods - you get what the pistons dont have enouth of movment then they are cold (basicly pistons are stuck on the rods and kinda hard to move by hand if they are cold, but its enouth to heat them up a bit and they start to move...) This was the main reason what i aint used these pistons in my project (cuz i wanted to turbo my engine faster and aint had time to solve all this ) BUT, i asume using your STOCK 7A Pins with along GZE pistons - everything should and i say SHOULD be good... i dont know yet, i will try later about this... Good luck guys. -------------------- Ex celica owner - just a guy from other side of the pond...
Full custom Projects from restoration to performance builds <<<<<< DCw / JDMart >>>>>>> |
Oct 30, 2005 - 11:32 PM |
Enthusiast Joined Mar 31, '04 From Summerville, SC Currently Offline Reputation: 5 (100%) |
QUOTE(doGGy @ Oct 30, 2005 - 8:35 PM) K, time to write it again. As i know for now im the only one who TRYED TO PUT GZE pistons in the 7A. First: EVERYTHING FITS LIKE IT SHOULD BE. !!!!!!BUT!!!!!! I used GZE (or GE)20mm wrist pin pistons. The wrist pin of the GZE is the same diameter as the 7A pins. BUT wrist pins of the GZE (or GE) pistons are FULL FLOATING, 7A pins are PRESS FITED. Difference is what 4AGZE rods have coper/bronze insert in the top of the rod, AND wrist pins float in it, and there is the oiling chanel in the rods for oiling the pins. 7A rods DO NOT have pin insert, DO not HAVE oiling cuz pin is pressure fitted and DOESNT move in the rod pistons move on the pin. Then puting GZE (or GE) pistons MIND one thing: GZE pistons pins are full floating, so the restriction of the pin floting is in the piston. Then you press fit the GZE pins in the 7A rods - you get what the pistons dont have enouth of movment then they are cold (basicly pistons are stuck on the rods and kinda hard to move by hand if they are cold, but its enouth to heat them up a bit and they start to move...) This was the main reason what i aint used these pistons in my project (cuz i wanted to turbo my engine faster and aint had time to solve all this ) BUT, i asume using your STOCK 7A Pins with along GZE pistons - everything should and i say SHOULD be good... i dont know yet, i will try later about this... Good luck guys. [right][snapback]350743[/snapback][/right] We already know this, what about the compression ratio? That's the question that hasn't been confirmed. -Doc -------------------- -Dr Tweak, 6GC's resident engine swap wiring expert extraordinaire Click here to see my swaps drtweak@phoenixtuning.com |
Lo-Fi Version | Time is now: December 4th, 2024 - 3:03 PM |
