> Water pump differences, ST185 & ST205
post Apr 21, 2005 - 9:41 PM
Defgeph
Joined Apr 17, '03
From Rockland NY
Is there any difference between the st185 & st205 water pumps ?
Thanks
Def
I will return one day.
post Apr 22, 2005 - 12:06 AM
sounds like the type of thing the mr2oc.com guys would know.
post Apr 22, 2005 - 1:58 AM
Kwanza26
Joined Dec 27, '03
From Nor Cal
Waterpumps attach to the block... so they should interchange just fine even if they are slightly different.
post Apr 22, 2005 - 3:43 PM
Defgeph
Joined Apr 17, '03
From Rockland NY
QUOTE(Kwanza26 @ Apr 22, 2005 - 1:58 AM)
[right][snapback]276088[/snapback][/right]
What about the fact that the 205 is water cooled and the 185 is not ?
I think this would make a difference, no ?
Thanks,
DEF
post Apr 22, 2005 - 3:48 PM
Kwanza26
Joined Dec 27, '03
From Nor Cal
QUOTE(defgeph @ Apr 22, 2005 - 8:43 PM)
Thanks,
DEF
[right][snapback]276447[/snapback][/right]
Hehe... that's refrence only to the intercoolers. The engine cooling system is mostly separate from that...
post Apr 22, 2005 - 3:50 PM
Defgeph
Joined Apr 17, '03
From Rockland NY
are you sure cause if you look at the BGB of the coolant flow it shows that the st205 shares the water pump for the rad and intercooler.
post Apr 22, 2005 - 3:53 PM
Defgeph
Joined Apr 17, '03
From Rockland NY
post Apr 22, 2005 - 3:58 PM
my guess is that the pump is the same. i dont think the st205 intercooler uses coolant from the motors supply. it has its own heat exchanger, pump and its own coolant supply. so buying an st185 waterpump would work fine for your setup.
This post has been edited by lagos: Apr 22, 2005 - 3:59 PM
post Apr 22, 2005 - 3:59 PM
Defgeph
Joined Apr 17, '03
From Rockland NY
post Apr 22, 2005 - 4:01 PM
Defgeph
Joined Apr 17, '03
From Rockland NY
I guess I'm getting confused because I see the red hoses in the last pic.
So the only thing to worry about is the intercooler water pump? as far as availablity.
post Apr 22, 2005 - 4:02 PM
Kwanza26
Joined Dec 27, '03
From Nor Cal
If you look at that diagram... the waterpump does not attach to anything aside from the pump housing. The pump housing is where the inlet, therostat, and various coolant lines are attached to. Let me also clearify, there are two parts to a complete waterpump. The housing, and the pump itself. When you buy a waterpump, usually you'll only buy the pump and the housing is re-used. I'm pretty certain the waterpumps themselves are interchangeable... but there may be differences in the pump housings...
post Apr 22, 2005 - 4:06 PM
Defgeph
Joined Apr 17, '03
From Rockland NY
do you know if the intercooler pump ever fails could someone rebuild it ?
post Apr 22, 2005 - 4:18 PM
yeah...dont worry too much about the intercooler pump. i think you can even you the 4th gen alltrac pump if you really had to.
post Apr 22, 2005 - 7:46 PM
Mr_E
Joined Nov 16, '04
From UK
QUOTE(defgeph @ Apr 22, 2005 - 3:50 PM)
[right][snapback]276458[/snapback][/right]
No it flippin doesn't......
JDM ST205
Blitz Spec NUR Exhaust, somewhere over $1000
Needing another one 18000 miles later, bloody annoying.
Lo-Fi Version Time is now: November 25th, 2024 - 8:33 AM
