> Arospeed Header
post Apr 22, 2005 - 2:33 PM
Drew-887
Joined Jan 5, '05
From Upper Darby, PA(5 min away from Philly)
I need some help with this. Would this header fit on my 95 Celica ST?
http://www.arospeed.com/product_info.php?c...products_id=286
post Apr 22, 2005 - 5:17 PM
yes it will fit with a small modification
better to go with ebay though
post Apr 22, 2005 - 6:25 PM
Drew-887
Joined Jan 5, '05
What kind of small modification and how much do you think it will cost?
post Apr 22, 2005 - 7:08 PM
RedSunCelica
From San Diego CA
QUOTE(Drew-887 @ Apr 22, 2005 - 4:25 PM)
[right][snapback]276556[/snapback][/right]
small modifications = take it to a muffler shop. the mid pipe is at a different angle which hits the oil pan also it needs to be extended a little.
post Apr 23, 2005 - 12:25 PM
Drew-887
Joined Jan 5, '05
post Jun 10, 2005 - 4:02 AM
Illyont
Joined Apr 8, '05
From Norway
I'm rather bringing back this thread than to start my own.. I guess this also goes for a 99 ST?
I would have to talk to my shop before buying then, to see if they can do that kind of work.
This must be one of the only aftermarket headers made for the 1.8 7A-FE, and it's to bad it doesn't bolt on to the Celica. Why on earth do they make a performance header for the Corolla 1.8, and leave out the Celica? Stupid..
Can someone change the parts database:
"This is a header made specifically for the sixth generation Toyota Celica. The part number for the 7A-FE header is ARO800911, and for the 5S-FE, it is ARO800912."
No, it is made for a Corolla 93-97, and not the Celica. And not for 94-99..
This post has been edited by Illyont: Jun 10, 2005 - 4:13 AM
post Jun 10, 2005 - 10:31 AM
this isn't even made anymore this should be removed from the parts database
post Jun 10, 2005 - 11:10 AM
yarik83
Joined Nov 22, '04
From FL
buy a corolla header, cut it right below 4-2-1, cut pipe at angle, ecut and make sure header pipe that goes to cat converter is at a much bigger angle
Captain Pessimist
Lo-Fi Version Time is now: December 4th, 2024 - 6:51 AM
