> auto -> manual E153, Questionable parts
post Apr 22, 2005 - 6:03 PM
Consynx
Joined Dec 25, '02
From Pittsburgh/Clairton, PA
Trying to figure our what parts i can use from the MR2 or the ST185(since they are sometimes cheaper)
Here's the list from Sev's posts that i have questiones about
the pedals not as much as the cylinders + lines, but the rest yea...
-Shifter
-Shift Cables
-Clutch Master cylinder
-Slave cylinder
-Clutch metal fluid lines
-Rubber clutch line
-Clutch pedal assembly
-Manual brake pedal (just the pedal because John told me you dont need the whole assembly)
-Manual Transmission Drivers Side Mount
-Starter Relay for Manual
-2 bolts for Trans- 12 by 1.25 (1 is 65mm other is 75mm)
post Apr 22, 2005 - 6:04 PM
Consynx
Joined Dec 25, '02
btw, no Guesses please...i dont have money to juggle so im just searchin for the almost definates...
post Apr 22, 2005 - 6:11 PM
OrbitalGT95
Joined May 3, '04
From pittsburgh
Now SR powered
post Apr 22, 2005 - 10:42 PM
Consynx
Joined Dec 25, '02
bump
Lo-Fi Version Time is now: December 1st, 2024 - 3:42 PM
