Apexi turbo timer installed, replaced clock |
Apr 23, 2005 - 3:31 PM |
Enthusiast Joined Oct 10, '04 From New Jersey Currently Offline Reputation: 0 (0%) |
here is a picture of my Apexi turbo timer i just put in my celica. i put it in place of my clock after i herd a few people saying some one should put it their, so i did . hope u like it....tell me what you think.
[IMG] http://img132.echo.cx/my.php?image=apexitimer1so.jpg [/IMG] This post has been edited by StreetRacing10PSI: Apr 23, 2005 - 4:31 PM |
Apr 23, 2005 - 7:10 PM |
Enthusiast Joined Nov 29, '04 Currently Offline Reputation: 5 (100%) |
Nice! -Josh |
Apr 23, 2005 - 9:36 PM |
thanks, its a lot easyer to install than i thought
Apr 23, 2005 - 9:56 PM |
its nice but what if wanna know the time?
Apr 23, 2005 - 9:57 PM |
Enthusiast Joined Nov 16, '04 From UK Currently Offline Reputation: 0 (0%) |
Pretty easy to install as long as you have the plug and play wiring harness.
My Blitz unit lives to the lower left of the steering column. -------------------- JDM ST205
Blitz Spec NUR Exhaust, somewhere over $1000 Needing another one 18000 miles later, bloody annoying. |
Apr 23, 2005 - 10:00 PM |
i figured, if i wanna know the time, i would just look at my cell phone, or my head unit when i get a new one.
Apr 23, 2005 - 10:24 PM |
Looks nice.
Do you know if the wires in that main harness can be cut and re-soldered? It'd be neat to drill a hole and have the harness going through that. -------------------- New Toyota project coming soon...
Apr 23, 2005 - 10:26 PM |
iam really not sure, i dont know why you couldnt tho.
Apr 23, 2005 - 10:45 PM |
Enthusiast Joined Jul 19, '04 From Los Angeles, CA Currently Offline Reputation: 2 (100%) |
looks good, but, do you have a turbo? it doesnt say in your profile?
edit:: o. i see you just got one. we definately need to see it after installation! This post has been edited by CheesyLobster: Apr 23, 2005 - 10:46 PM |
Apr 23, 2005 - 10:53 PM |
i just ordard one a few days ago, ill hopefully install it by next weekend
Apr 24, 2005 - 2:14 AM |
Not really replacing it as your just covering it. I fitted mine next to my dimmer switch
Apr 24, 2005 - 8:50 AM |
no, i removed the clock from behind the dash, it was two clips, and then glued a piece of black plastic to the back and then used the double sided tape to tape it over were the clock origonaly was.
Apr 24, 2005 - 11:34 AM |
Enthusiast Joined Jan 10, '04 From Shoreline, WA Currently Offline Reputation: 4 (100%) |
by the looks of it you could probilby just put it where the clock was behind, the screen looks to be about the right size, then just srill a hole for the button on there and its fully built in.
but looks good, If i end up with one its gana go where the ash tray/pocket is to kinda hide it as best as i can. -------------------- |
Apr 24, 2005 - 12:17 PM |
Enthusiast Joined Jun 4, '04 From DeKalb Illinois Currently Offline Reputation: 0 (0%) |
I like it, looks good. But yeah if you could re-run that wire it would look even better...
Apr 24, 2005 - 12:19 PM |
i will as soon as i block off the vents and add my boost, oil pressure, and oil temp guages.
Lo-Fi Version | Time is now: December 4th, 2024 - 6:09 PM |
