> Distributor, How do you adjust it to get some boost?
post Apr 24, 2005 - 11:13 AM
sixthgen
Joined Jun 1, '04
From Texas
Please help and tell me. Thank you.
post Apr 24, 2005 - 1:40 PM
GT4WRC
Joined Mar 17, '05
From Auckland, New Zealand
Can you be more specific? Sounds like you are asking if you can adjust the distributor to get boost pressure confused.gif
Try giving us a clue on what car, motor, year etc you are referring to wink.gif
Gary
1994 ST205 Celica GT-FOUR Group A WRC - running in new engine
1993 Rover 220 GTi tarmac rally car (under construction) 3SGE power here we come....
GT-Four spec list
post Apr 24, 2005 - 2:14 PM
JoeyIsFunny
Joined Apr 18, '05
From Atlanta, Georgia
I believe he is talking about advancing ignition timing for a few added horses. If this is the case, you would be best off taking it to a good mechanic and asking if it would be safe to advance your ignition timing a few degrees. Most likely they will say yes, provided that you upgrade to mid-high grade gasoline for however long you have your timing advanced. If you stay at low(87) grade, you are gauranteed to get some detonation in the cylinders which is B.A.D. Its not an easy task to do unless you have a timing gun, and actually know what you are doing/looking for.
Best bet, take it to a mechanic and have them do it as high as safely possible. Oh, and fill up with medium (for slight advancing) or high (for lots of advancing) grade gas before you go.
post Apr 24, 2005 - 6:14 PM
Junior
Joined May 5, '03
From Toronto
anyone know the stock ignition timing of a 5sfe from a 94 gt. I'm tired of buying high octane fuel.
post Apr 25, 2005 - 1:55 AM
Silvan
Joined May 7, '04
From Leeuwarden, Netherlands
I thought this was only possible on a 7A-FE, cause the GT and GT-4 ecu's are capable of retarding and advancing timing itself, or am I mistaking?
post Apr 26, 2005 - 3:29 PM
97GTinKC
From KC
I believe it was 96 and newer GT's (and probably newer ST's as well) that had no timing adjustment. earlier ones all you need is a timing light and I believe a 12mm wrench.
post Apr 26, 2005 - 4:09 PM
nik
Joined Sep 30, '02
QUOTE(97GTinKC @ Apr 26, 2005 - 1:29 PM)
[right][snapback]278441[/snapback][/right]
on 94-95 ST they came with obd1 so you can adjust the distributor by loosing 2 12mm bolts turn clock wise to advance and counter clock to retard make sure you use a timing gun
post Apr 26, 2005 - 5:50 PM
erics1one
Joined Aug 27, '04
From Orange County, CA
QUOTE(Junior @ Apr 24, 2005 - 4:14 PM)
[right][snapback]277332[/snapback][/right]
Stock setting is 10 deg
post Apr 26, 2005 - 10:13 PM
Dr_Tweak
Joined Mar 31, '04
From Summerville, SC
Don't forget that you need to put a jumper wire in the Diagnostics plug. Someone probably has a pic of which ones on here...
Click here to see my swaps
drtweak@phoenixtuning.com
post Apr 28, 2005 - 3:03 PM
nowitzon
Joined Apr 6, '05
From homosassa,florida
how can u do it for an st i tried yesterday with no sucsess any other wa y i can get it
FOR 21 YEARS I DEALT WITH THE RAIN,
ONLY TO FIND OUT THAT I COULD STOP THE PAIN,
SO NOWITZON!!!
post Apr 28, 2005 - 4:52 PM
Hanyo
Joined Aug 16, '03
From Bay area
QUOTE(nowitzon @ Apr 28, 2005 - 1:03 PM)
[right][snapback]279604[/snapback][/right]
you can only adjust the distributor on the 94-96 model celica's.
post Apr 28, 2005 - 7:04 PM
nowitzon
Joined Apr 6, '05
hey i have a limited celica too i really think there were more than 3500 of these produced
SO NOWITZON!!!
post Apr 30, 2005 - 12:23 AM
Hanyo
Joined Aug 16, '03
From Bay area
i would think the people who own limited editions would love there cars more.. and be posting here.
and there is 3500 each year.. so in actuallity there is alot of limted edition celica's
post Apr 30, 2005 - 9:53 PM
nowitzon
Joined Apr 6, '05
id love to find out how many were left of my year and type. u know? cause with all accidents and people not caring about their car theres got to be not that many left, maybe 1000? 8 years is a long time
SO NOWITZON!!!
Lo-Fi Version Time is now: November 26th, 2024 - 4:38 AM
