UPDATED PRICES: Phoenix Tuning Stage I Turbo Kit, For '94-'99 Celicas |
Apr 27, 2005 - 7:54 AM |
Enthusiast Joined Feb 3, '05 From Tampa, Florida Currently Offline Reputation: 2 (100%) |
lol I see the guys over there welcome you with open arms with a turbo kit. Over here you get hassled...lol iam still interested though. I think its a good way to get some decent HP for those who arent hardcore with spending money and dropping mad amounts of money into there car. Have you had any dibs yet on either of these sites Raven?
-------------------- I'am Reinventing the SLow Lane.....
Apr 27, 2005 - 8:00 AM |
its not hassling its just making sure its done right
and to make sure he knows what he's doing i welcome a turbo kit for this community its been needing one i just want to make sure its a good one |
Apr 27, 2005 - 9:30 AM |
Enthusiast Joined Sep 30, '02 From Washington Spokane / Coeur D' Alene Idaho Currently Offline Reputation: 11 (100%) |
QUOTE(raven_101 @ Apr 26, 2005 - 8:12 PM) Nik, did you get my email? [right][snapback]278607[/snapback][/right] yeah i got it. I dont know about the price tag but he is trying to make a direct bolt on kit like i had its not real hard (it is if your not mechically inclined) but it is time consuming.You still can do it yourself or buy a kit less time. now to the dirt do you have a prototype yet? you need dyno sheets with air fuel readings dyno video maybe A list of parts that come in each kit. is there any options? what diameter piping? what bov? turbo internal or external gate? is the manifold coated? are you gong to do injectors? spark plugs? one step colder what gap there are alot of little things how are you hiding the boost from the ecu i used check valves or are you going to use a new map sensor? warrenty? This post has been edited by nik: Apr 27, 2005 - 9:33 AM -------------------- yea your 3sgte is cool but ill stick to my 7agte
Apr 27, 2005 - 9:44 AM |
one of the members ZIPSTRIPS has also turboed his 7afe check it out and confirm this, i dont think hes on here much anymore though.
Apr 27, 2005 - 9:51 AM |
QUOTE(celica47 @ Apr 27, 2005 - 7:44 AM) one of the members ZIPSTRIPS has also turboed his 7afe check it out and confirm this, i dont think hes on here much anymore though. [right][snapback]278793[/snapback][/right] i bought his turbo, manifold and dp. I email him once in a while but i think he is into the hole 240 seen now as far as i know there is only 3 working kits mine forkee one other guy This post has been edited by nik: Apr 27, 2005 - 9:52 AM -------------------- yea your 3sgte is cool but ill stick to my 7agte
Apr 27, 2005 - 9:53 AM |
what do you mean by hes in the hole 240?
Apr 27, 2005 - 9:55 AM |
Enthusiast Joined Mar 31, '04 From Summerville, SC Currently Offline Reputation: 5 (100%) |
playr158, I'm not going to be "claiming" anything. Either I'm going to build a kit that makes 200hp, or I'm not.
nik, thanks for the good questions. I am picking up the test Corolla this weekend and I will start building that kit. That one will be done first and then the Celica kit once I get one to work with. The dyno sheet will be provided. The list of parts that I have in the first post it pretty accurate. As far as options, I've had a number of people request certain specific parts be included for them. I have no problem customizing kits that way. For example, if you want to choose your own turbo, that's fine. The intercooler piping will most likely be 2" or 2 1/4", but I will test it to make sure. The wastegate is internal. I have not decided on the coating. Injectors will not be included with the stage I kit. I'm planning on copying the 3SGTE gap for the time being, but that needs to be tested. I'll be using check valves similar to what you did. You mentioned that you needed to adjust the throttle plate? What needed to be changed and why? -------------------- -Dr Tweak, 6GC's resident engine swap wiring expert extraordinaire Click here to see my swaps drtweak@phoenixtuning.com |
Apr 27, 2005 - 10:00 AM |
raven this is what i would do 3 stages
stage 1 (hot air) 5psi manifold FMU turbo w/ internal waste gate oil pan drain line feed line filter check valves bov piping (from turbo to intake) boost guage MBC est whp 140 stage 2 (gettin cooler) 8-9.5psi all of the above + new piping intercooler proven 170whp 180 torque stage 3 (hacking the brain) 10+psi piggy back system est 200whp options: spark plugs wires 2 stage mbc upgrade bov powder coating underdrive pully i should patent this This post has been edited by nik: Apr 27, 2005 - 10:30 AM -------------------- yea your 3sgte is cool but ill stick to my 7agte
Apr 27, 2005 - 10:01 AM |
QUOTE(celica47 @ Apr 27, 2005 - 7:53 AM) what do you mean by hes in the hole 240? [right][snapback]278799[/snapback][/right] nissian 240 sx -------------------- yea your 3sgte is cool but ill stick to my 7agte
Apr 27, 2005 - 10:04 AM |
QUOTE(raven_101 @ Apr 27, 2005 - 7:55 AM) You mentioned that you needed to adjust the throttle plate? What needed to be changed and why? [right][snapback]278801[/snapback][/right] the dyno guys and i did a little adjusting while on the dyno the first time why...... i might tell you -------------------- yea your 3sgte is cool but ill stick to my 7agte
Apr 27, 2005 - 10:06 AM |
lol patent the normal turbo setups nik?
lol |
Apr 27, 2005 - 10:09 AM |
QUOTE(playr158 @ Apr 27, 2005 - 8:06 AM) lol patent the normal turbo setups nik? lol [right][snapback]278808[/snapback][/right] the 3 stage idea for the 7afe but it probably wont happen -------------------- yea your 3sgte is cool but ill stick to my 7agte
Apr 27, 2005 - 10:13 AM |
It's not just me, it's us. Why did they need to be adjusted, and what changes did you make?
Also I refuse to market a kit that's not intercooled. I will be breaking the kits up into three different ones though, which I'll go into more detail about tonight. This post has been edited by raven_101: Apr 27, 2005 - 10:14 AM -------------------- -Dr Tweak, 6GC's resident engine swap wiring expert extraordinaire Click here to see my swaps drtweak@phoenixtuning.com |
Apr 27, 2005 - 10:15 AM |
Enthusiast Joined Aug 30, '02 From Anaheim, CA Currently Offline Reputation: 0 (0%) |
QUOTE(nik @ Apr 27, 2005 - 6:51 AM) QUOTE(celica47 @ Apr 27, 2005 - 7:44 AM) one of the members ZIPSTRIPS has also turboed his 7afe check it out and confirm this, i dont think hes on here much anymore though. [right][snapback]278793[/snapback][/right] i bought his turbo, manifold and dp. I email him once in a while but i think he is into the hole 240 seen now as far as i know there is only 3 working kits mine forkee one other guy [right][snapback]278798[/snapback][/right] and forkee got his kit from me. and to the guy(94ST2) that asked about me running 17psi i drive a WRX buddy. -------------------- 1994 Celica GT4 WRC Edition
@gt4.wrc on Instagram |
Apr 27, 2005 - 12:34 PM |
Enthusiast Joined Jun 4, '04 From Northern New Jersey Currently Offline Reputation: 2 (100%) |
I know Raven personally... hes THE doc. when it comes to cars... ill vouch for him. he knows his $hit and excels in it and i look forward to seeing his kits in action!
bboy -------------------- ..(formerly daily driven) 3S-GTE powered celica currently set @ 12psi.. |
Apr 27, 2005 - 2:51 PM |
alright thats what iam talking about Raven has some crediability. Nik thanks for clearing that up ,240 sx lol iam dumb. Raven you know what else would be nice just a suggestion i think pressure2 was talking about it and i think 97scelica knows about it, a water injection system to help add more cooling wouldnt be bad to look into.
Apr 27, 2005 - 5:46 PM |
Enthusiast Joined Apr 12, '05 From chicago (ft. hood) Currently Offline Reputation: 0 (0%) |
this turbo setup sounds good I'm starting to save my money now so I could get it
Apr 27, 2005 - 10:45 PM |
bboy, celica47, jav714, thanks for the votes of confidence.
By the way, raven_101 is a REALLY old screen name, my name is Dr Tweak and that's what everyone knows me by. I'll see if Coomer can fix that up for me. -------------------- -Dr Tweak, 6GC's resident engine swap wiring expert extraordinaire Click here to see my swaps drtweak@phoenixtuning.com |
Apr 28, 2005 - 7:15 AM |
http://www.aquamist.co.uk/cp/cp.html heres that cooling part for turbos if anybody cares to take a look.
May 1, 2005 - 8:11 PM |
Well guys, I managed to pick up a 5th generation Celica this weekend. I've got some repairs on it and then I'll develop the turbo kit for it which will be the jump-off point for the 6th gen Celica and the Corollas.
-Doc -------------------- -Dr Tweak, 6GC's resident engine swap wiring expert extraordinaire Click here to see my swaps drtweak@phoenixtuning.com |
Lo-Fi Version | Time is now: December 2nd, 2024 - 8:30 AM |
