> Venom Control Module
post Apr 12, 2003 - 12:52 AM
94Toy
Joined Apr 3, '03
From Omaha, Ne
To all those people that have Venom Control Module, how do you like it, and did it make a big difference in performance.
Thanks
John
post Apr 12, 2003 - 1:29 AM
Guest_Matthew_*
control module for what ???
nitrous
if that is what it's for all it does is let you open the nitrous at wide open throttle unlike nos which engages at any RPM.
post Apr 12, 2003 - 1:42 AM
CelicaGT6G
Joined Apr 5, '03
From Smithfield, RI
Huge differance to me. Very noticable pickup. alot more ballsie. I love it man. Well worth the money. definatly worth its weight in gold.
post Apr 12, 2003 - 10:46 AM
FallenHero
Joined Dec 26, '02
From Alabama
Everybody I've talked to about the VENOM fmu said they loved it. People on here usually bash it though.
post Apr 12, 2003 - 3:33 PM
97sccelica
Joined Aug 30, '02
From Anaheim, CA
QUOTE (94Toy @ Apr 11, 2003 - 10:06 PM)
Thanks
John
you mean the venom 400?
i have one and it makes a whole lot more passing power. the car will still throw you hard into your seat even when you are at 50mph
1994 Celica GT4 WRC Edition
@gt4.wrc on Instagram
post Apr 13, 2003 - 7:23 PM
FallenHero
Joined Dec 26, '02
From Alabama
what did you pay for it?
post Apr 13, 2003 - 8:05 PM
Guest_Matthew_*
what is this product we are talking about?
post Apr 13, 2003 - 8:47 PM
sirrahtap
Joined Dec 1, '02
From minneapolis
yeah, someone needs to clear this all up in one post.
what exactly are we talking about?
what does it do?
what are the benefits?
how much does it cost?
post Apr 13, 2003 - 10:31 PM
Kwanza
Joined Apr 8, '03
From NorCal
http://www.coximport.com/venom/400.html
post Apr 14, 2003 - 1:11 AM
Mynzeyes
From Franklin/Nashville, TN
i heard and read some stuff about how it just changes the throttle positioning sensor so that the ecu thinks the throttle is at WOT a lot earlier than it should, therefore causing the "boost" of power you feel. it would manipulate your expectations b/c you would not be expecting the feeling of WOT at about 1/2 to 3/4 throttle.
but, i don't approve or disapprove of this product based on the fact i've never personally delt w/ it, i'm just reporting what i've heard/read. wink.gif
-John-
AIM==Mynzeyes
post Apr 16, 2003 - 12:21 AM
MadLion90
Joined Nov 15, '02
From Rhode Island
I have it and i love it. Def help my st get up to 115 easy and quickly. And you can def tell the difference. Only problem is that it wastes more gas when used. Also I don't recommend using the things they give you to tap into the ecu,map,tps senors wires. My TPS recently got fried because of the bad wire tapper. Just cut and twist instead of that wire tapper they give you.
--Mike--
post Apr 16, 2003 - 12:17 PM
White_GTS
Joined Jan 13, '03
From Toronto, Canada
Is this similar to this product? http://www.jetchip.com/
I'm looking for soemthing good that can give me more power. I have heard that a module would do the trick. Which one is good to have in your car? How did you guys install it?
post Apr 16, 2003 - 12:51 PM
Kwanza
Joined Apr 8, '03
From NorCal
QUOTE (White_GTS @ Apr 16, 2003 - 9:31 AM)
No...
Jetchip is a modification added to the stock ECU...
Venom 400 is a standalone unit.
post Apr 16, 2003 - 12:55 PM
White_GTS
Joined Jan 13, '03
QUOTE (Kwanza @ Apr 16, 2003 - 10:05 AM)
No...
Thanks for the info my friend. So which one is better?
Have you heard of a product called Spiral Max? Some people have them installed on there car and they say you get more power. http://www.spiralmax.com/
post Apr 16, 2003 - 10:40 PM
FallenHero
Joined Dec 26, '02
From Alabama
The Venom is a piggy back.
Jet also makes a simmilar piggy back. I was going to ask charlie how hard it is to wire, so if you're reading this dude, how hard is it to wire a afc-venom-jet piggy back?
My supplier get's JET products, So I might be able to get them really cheap. He said they were really hard to wire though...
post Apr 16, 2003 - 11:18 PM
98celica3
Joined Aug 30, '02
From North Carolina
I have the Venom VCN 400 and i also love it. More power through the higher gears 3rd thru 5th. Definatley worth the money!
adam
MISS THE CELI, BUT...
post Apr 17, 2003 - 12:55 AM
Kwanza
Joined Apr 8, '03
From NorCal
QUOTE (White_GTS @ Apr 16, 2003 - 10:09 AM)
I can't say which is better. Don't have either (for the price...I can buy a turbo manifold and ghettofab a turbo kit). All I know is, these ECU piggy-back systems and ECU chips are designed to manipulate/adjust the stock ECU and making it (or rather the engine) perform more agressively as opposed to economically.
As far as the spiralmax fin thingy goes, sticking something in your intake pipe causes restriction, which is more harmful than helpful. I've never tried it, but baseing my guess on common sense, I'd say, don't bother. A little stationary fin does not cause air to spin. Air will only spin and increase in flow if energy is exerted. If you're set on trying it out, make one. From the pictures, the design (for me) can be easily duplicated. Either way, if you can get more air to flow through the intake, via a fan or whatever, it's useless unless you can adjust the fuel mixture with it... so a simple fan is only doing what an intake already does...
post Apr 17, 2003 - 7:49 AM
White_GTS
Joined Jan 13, '03
Kwanza
Thanks foir the info. I guess your right. Also the fin may break off and end up getting sucked into the engine which is not cool at all.
98celica3
How muich of a difference do you feel? Did you do a dyno of before and after it being installed? What was the price damage?
post Apr 18, 2003 - 11:39 PM
NEVERSTOP
Joined Nov 4, '02
From Davenport Iowa
you can also just adjust your throttle sensor position - not quite as good of a mod but all it cost is the time to undo a few screws and move the sensor around and then test drive it and find which postion you like best - other wise the venom 400 is a good investment
post Apr 20, 2003 - 6:24 PM
FallenHero
Joined Dec 26, '02
From Alabama
I would say Jet. In the picture it looks as though you can adjust it on the fly.
Lo-Fi Version Time is now: November 28th, 2024 - 12:59 PM
