> Koni Yellow install, 94 ST.. Ive searched
post Apr 25, 2005 - 4:31 PM
ModdedST
Joined Nov 24, '02
The shocks do come with some sort of instruction but as we know the install may involve welding and what not. I dont want to give it to my mechanic and sketch him out telling him this without directions. Is there a specific writeup on how to do this on the celica?
post Apr 25, 2005 - 5:34 PM
BLINKYxMUNKEY
Joined Nov 12, '03
From Crestview, Florida
when i installed my konis, all i had to do was cut the rear shocks to where the old shock will slide out.
FlickR
post Apr 25, 2005 - 6:32 PM
LewFX
Joined Jan 28, '05
From Redondo Beach, CA
just get the bilsteins, and dont deal with cutting or welding! 2 replacement rears and 2 front inserts.
post Apr 26, 2005 - 10:51 AM
ghostdog
From ny to philly
your mech will figure it out. the fronts are easy, so I did them myself. the rears I took my mechanic, he said it was pretty straightforward
post Apr 26, 2005 - 12:14 PM
isn't that backwards ghost?
cause the rear are new struts entirely and the fronts are inserts?
post Apr 26, 2005 - 12:43 PM
AndyST4
Joined Feb 3, '05
From Portland, OR
nope the fronts are replacements and the rears you need to cut the top off the stock shock housing and drill a hole in the bottom and the koni's slide in and bolt through the hole
post Apr 26, 2005 - 1:02 PM
ok i know thats wrong for a fact
the FRONT is insert
the rear is new
cause i've already replaced my rears with NEW assembly the whole thing
the front i look up and are inserts
this is a first time i hear the rear are inserts?
post Apr 26, 2005 - 1:10 PM
AndyST4
Joined Feb 3, '05
From Portland, OR
maybe the koni site is wrong or maybe they are both inserts, I don't have them on my car so I don't know for sure, but when I was going to buy a set I read the instructions on the install and it said to cut the top off the rear housing and empty them out, then bolt the new koni inserts in.
post Apr 26, 2005 - 1:41 PM
LewFX
Joined Jan 28, '05
maybe they just mean cut the bottoms of the strut and empty old shock insert and insert new. not the rear strut itself.
post Apr 26, 2005 - 5:36 PM
BLINKYxMUNKEY
Joined Nov 12, '03
QUOTE(playr158 @ Apr 26, 2005 - 1:02 PM)
the FRONT is insert
the rear is new
[right][snapback]278353[/snapback][/right]
the rear on konis are inserts. you have to cut the top of the orignal shock and pull it out. then you have to drill a hole on the bottom, slide the new insert in, and with the hole you screw the assembly back together. i can try and get a copy of the instructions up soon.
edit... found a pic. of the rear struts.
This post has been edited by BLINKYxMUNKEY: Apr 26, 2005 - 8:57 PM
FlickR
post Apr 26, 2005 - 6:58 PM
ghostdog
From ny to philly
word.
QUOTE(BLINKYxMUNKEY @ Apr 26, 2005 - 6:36 PM)
the FRONT is insert
the rear is new
[right][snapback]278509[/snapback][/right]
post Apr 27, 2005 - 5:45 PM
ModdedST
Joined Nov 24, '02
QUOTE(BLINKYxMUNKEY @ Apr 25, 2005 - 3:34 PM)
[right][snapback]277906[/snapback][/right]
What?
post Apr 30, 2005 - 12:31 AM
Hanyo
Joined Aug 16, '03
From Bay area
you should post a picture of the old shock insert.
i'd like to see how they look like.
post May 14, 2005 - 4:54 PM
magnum
Joined May 13, '05
From Tipperary Ireland
QUOTE(AndyST4 @ Apr 26, 2005 - 6:43 PM)
[right][snapback]278340[/snapback][/right]
i
i fitted only this week and this is how we done it aswell but the fronts were inserts also
Cheer's
Mike (,")
www.Toyota-irl.com
post May 15, 2005 - 12:50 AM
This post has been edited by playr158: May 15, 2005 - 12:52 AM
post May 16, 2005 - 10:53 AM
S_C_M
Joined Mar 2, '04
From Louisiana, USA
No welding, at least not on my '95 or on any install I've seen pictured. Both front and rear struts are inserts with the Koni setup, only the rear require some cutting and drilling.
BLINKYxMUNKEY's instructions and pics above are accurate.
Lo-Fi Version Time is now: November 27th, 2024 - 6:25 PM
