> Another sub problem, helpppp
post Apr 25, 2005 - 5:57 PM
funnyboy117
Joined Mar 9, '04
From San Carlos, CA
In these past two days, when I turn my subs up moderately high, they go crazy and start hitting randomly. At this point I turn down the music, and the random beats continue for anywhere from 5-30 seconds. I normally listen to my music with the volume set at about 20 or 22, but now I can't even go above 18. Does anyone know how this could possibly happen?
post Apr 25, 2005 - 6:01 PM
thaimiishoe
Joined Mar 14, '05
From san jose, california
check all the wires on the subs & amps are plugged/touching.
and if it still persists, get a wire tester & check to make sure there is sufficient power produced in them.
This post has been edited by thaimiishoe: Apr 25, 2005 - 6:04 PM
2000 Celica GT-S 6spd
QUAIFE//TRD//AEM//FIDANZA//BEATRUSH//TRIAL//WINGSWEST//ALL JL AUDIO
post Apr 26, 2005 - 12:35 AM
pnoywitmustrdsau...
Joined Mar 28, '05
From California
umm damn you said that the beat coming from the sub is totally different from the song, yea check all the wires, i can stress that it might be power but, if you running 8 or 4 gauge wire then there is not problem, i guess then it must be your deck (HEAD UNIT)
post Apr 28, 2005 - 6:05 PM
funnyboy117
Joined Mar 9, '04
From San Carlos, CA
QUOTE(pnoywitmustrdsauce @ Apr 25, 2005 - 10:35 PM)
[right][snapback]278133[/snapback][/right]
What would be a problem with the head unit? Could I have blown the amp in it or something?
I checked all the wires and they're all connected just fine, I have to find out if my dad has a wire tester though and see if the power through the wires is all right.
post Apr 28, 2005 - 6:25 PM
SoundSlut_dotcom
Joined Feb 16, '03
CHECK THE GROUND! LOL
sorry i just find myself repeating that all the time.. its a common problem alot of people over see...
your ground wire may be getting too hot and u may need a thicker one.. its prob fried.. or in a bad spot...
post Apr 28, 2005 - 8:07 PM
GTchic98
Joined Feb 23, '05
From charlottesville, Va
BAD GROUND!!!!!!!
Lo-Fi Version Time is now: February 23rd, 2025 - 4:15 PM
