> Audio gone awry, rear tweeters buzz while engine is on
post Apr 25, 2005 - 10:16 PM
SinisterWhisper
Joined Nov 14, '04
Ok this has got to stop because im at my wits end. Lately my two rear tweeters buzz while my engine is on. Only the tweeters do this and only while there is a track playing (in between tracks it cuts off for a few seconds). I do not understand why its only those two and not also my front ones or why its only when the engine is running but ohh well. Hopefully I can work this out otherwise I will rip those suckers out in a heartbeat because it wrecks any music that is somewhat soft. Also the buzzing doesn't change regardless of volume go figure. frown.gif
post Apr 26, 2005 - 8:00 AM
rockstarbass1
Joined Apr 14, '05
From garfield hts. O-HI-O
do you have a inline fuse less then 18n inches from ur battery??
is so check to make sure you have good rca's that are running them (if useing an amp) and last make sure your rca's and or speaker wire is as far away from your power wire as possiable!
post Apr 26, 2005 - 12:24 PM
mikew04
Joined Feb 19, '04
From austin tx
Are they two ways, or components? Are they hooked up to an amplifier or are they running off your head unit? Sounds like you have a bad ground or there is a ground loop.
post Apr 26, 2005 - 3:38 PM
SinisterWhisper
Joined Nov 14, '04
QUOTE(mikew04 @ Apr 26, 2005 - 12:24 PM)
[right][snapback]278326[/snapback][/right]
they are components on an amp
post Apr 26, 2005 - 5:57 PM
mikew04
Joined Feb 19, '04
From austin tx
Sounds like a ground loop. Check your ground, make sure its a good one. If you still get noise, try grounding directly to your battery, or try a ground loop isolator and see if that works.
post Apr 26, 2005 - 11:25 PM
snadman
From Minnesota, USA
We got rid of buzz on a few of our display amps we just installed at best buy by running a 12ga wire from the ground connection on the amp itself to the black rca. I don't exactly know what this does, but I know that the senior installer did it to fix the huge problem we had with our new Alpine V12 amp.
95 Toyota Celica GT
Dead for now --> Soon to have a 3S-GTE
02 WRX --> This is for speed
- Borla Exhaust
- TurboXS BOV
- Custom CAI
02 Civic EX
- MB Quart Reference 5.25" Components
- Rockford MTX 8" Subs in the doors
- Alpine Type S Rear Fills
- 2x Alpine SWR-1042D Subs in a custom fiberglass box
- Alpine F345 Amp for the front doors
- Alpine M605 on each Type R
- Phoenix Gold wiring
- Alpine CDA-9855 Head Unit
- Alpine Amp link
- 2x Rockford Fosgate 1 Farad Caps
- The best Viper 791 alarm install ever
post Apr 26, 2005 - 11:50 PM
mikew04
Joined Feb 19, '04
From austin tx
He got rid of a ground loop smile.gif the outer sheild of an rca cable is grounded and used as a reference for the signal, so he connected the two so they both shared the same ground.
post Apr 27, 2005 - 10:32 PM
rockstarbass1
Joined Apr 14, '05
black rca?? i have red and white. also i seam to have that hissing problem type thing too. and i have a good ground it only seam to be my 4 chanel amp tho not my 2 ch for the sub tho. also i need some better rcas
Lo-Fi Version Time is now: November 27th, 2024 - 5:33 PM
