PROBLEM!, Heavy Vibration when over 85+ mph |
Apr 12, 2003 - 1:13 PM |
Enthusiast Joined Apr 9, '03 From Colleyville, TX Currently Offline Reputation: 0 (0%) |
I have a fear that something really bad is going on in my '94 Celica GT. A month and a half ago, it was involved in a front end collision. Not hard enough to mess up the frame or do any damage to the engine block, or radiator, or anything else under the hood, but hard enough to set off the airbags. (I put that there incase that might have something to do with this). Since then, when I get up to the higher speeds, 85+ mph, my car starts to vibrate and shake; a little at first but as I press closer to 100 mph, it starts to shake REALLY bad. Before it was in the wreck, it did not do this. Does anyone have any idea what might be happening; what is causing this?? |
Apr 12, 2003 - 1:17 PM |
Enthusiast Joined Dec 21, '02 From Italy Currently Offline Reputation: 0 (0%) |
you may check if a wheel is heavily damaged or maybe you've simply to readjust the camber angle and requilibrate the wheels...try to check your shocks and wheels and look if there are some visble damages
Apr 12, 2003 - 5:43 PM |
your alignment is prolly off....or a wheel could be out of balance,....hope its somthing simple like that..
13.6@108MPH, 5SFTE Powered |
Apr 12, 2003 - 9:44 PM |
all those things are right
and yea hopefully it is something simple as alignment |
Apr 12, 2003 - 11:05 PM |
Enthusiast Joined Jan 20, '03 From Denver, co Currently Offline Reputation: 0 (0%) |
Don't drive that fast then, j/k It sounds like you have a bent wheel, possibly something in the suspension bent, but as likely. Take it to a shop and have them balance your tires and align it
Apr 12, 2003 - 11:25 PM |
Enthusiast Joined Nov 11, '02 From Ohio Currently Offline Reputation: 0 (0%) |
I posted i topic like this like 2 months ago and their is some more ideas that i cant remember in that post. And if ya look there might be some helpful ideas that people posted. By the way i have the same problem but mines at 65. And i havent had luck with balancing or alingment..but thats just me..theres bunches of different things that could be wrong...Oh yeah, the topic I posted was called 'shaking steering wheel'...good luck!
This post has been edited by jumpinccv: Apr 12, 2003 - 11:26 PM |
Apr 12, 2003 - 11:41 PM |
Enthusiast Joined Feb 17, '03 From Adelaide, South Australia Currently Offline Reputation: 0 (0%) |
Could it be the CV joints? my old telstar (89) used to do this when it got up around 130Km/h...
Apr 13, 2003 - 2:00 PM |
Enthusiast Joined Nov 20, '02 From Chicago to Boston and back to Chicago Currently Offline Reputation: 0 (0%) |
I replied to the "shaking steering wheel" topic a couple of months ago because I had the problem when I drove over 80. I just found out that I REALLY need a wheel balance, and new CV joints.
Lo-Fi Version | Time is now: November 24th, 2024 - 6:57 PM |
