> ARRGGHH!!! Engine won't turn over!!!!, Just dropped dead.. any idea??
post Apr 12, 2003 - 3:53 PM
pflau
Joined Apr 8, '03
From New York City
Hi. My 98 Celica GT is stressing me out. It won't turn over frown.gif. I keep cranking and I would EVENTUALLY hear some VERY rough combustions but the engine just won't turn over. The strange thing is that the engine had always turned over instantly, and it turned over just fine two weeks ago. Last week I couldn't start the car, and left it at that because I didn't have time to deal with it. Now I still can't start the car.
I guess my question is: what could've changed in the space of ONE WEEK confused.gif? And the car went from starting just fine to no starting??? Any experience with similiar starting problems??? The care was always garaged so it's not like somebody messed up my car intentionally!?!?
Thanks in advance!!
phil
post Apr 12, 2003 - 4:00 PM
97sccelica
Joined Aug 30, '02
From Anaheim, CA
if it doesnt turn over, then that means the starter does not turn the crank at all, but from your description it sounds like it just wont start.
could you give some more details
and also check the voltage on your battery
This post has been edited by 97sccelica: Apr 12, 2003 - 4:00 PM
1994 Celica GT4 WRC Edition
@gt4.wrc on Instagram
post Apr 12, 2003 - 4:40 PM
pflau
Joined Apr 8, '03
From New York City
OK, I tried again.. it turned over but it was REALLY rough. To keep the engine from stalling I had to gun the gas pedal. And then I same the HUGE AMOUNT OF SMOKE from the exhaust and I had to turn off the engine because I didnt wanna mess it up.
I actually recorded the whole thing
this is how it sounded
I was almost flooding the engine at the end just to keep it running but then I saw the smoke...
The car was GOOD and had always been GOOD just two weeks ago!!!
phil
post Apr 12, 2003 - 4:44 PM
97sccelica
Joined Aug 30, '02
From Anaheim, CA
wow, that sounds like crap
do you have anyone that would try to put something in your car tank?(i kno that the doors on celicas are latched but someone might find a way in)
what color was the smoke? how old is the tank of gas? what condition are the plugs in? what are the fluids like?
post Apr 12, 2003 - 4:56 PM
pflau
Joined Apr 8, '03
From New York City
The car was GARAGED. I started it two weeks ago and it was fine.. I actually move it 12 inches in the garage (started it just to move it a little bit), shut off the engine, and closed the garage door. The car was in the garage for a week. Next time (a week ago) I opened the garage and tried to start the car I couldn't.
The smoke is WHITE.. which is just about the only good thing.. the tank of gas is about a month old and the tank is about 3/4 full. All the fluids are good. The car has no history of leaking fluids. The car has only 23k miles on it cus it's mostly a weekend car.
Does the engine sound like its misfiring??
phil
post Apr 12, 2003 - 4:58 PM
pflau
Joined Apr 8, '03
From New York City
I just checked the fuel cap.. when I opened it I got that hisssss sound which means that it hadn't been opened in awhile so I doubt if somebody put something in the tank
post Apr 12, 2003 - 5:17 PM
west_minist
Joined Oct 27, '02
From Barbados
Try removing 2 or more spark plugs and see if there are fouled up.
If so, clean them and try and start again.
post Apr 12, 2003 - 5:56 PM
97sccelica
Joined Aug 30, '02
From Anaheim, CA
that gas is on the old side. if you try to check/clean the plugs and that doesnt help, get one of those hand pump and pump out some of the gas and put in some fresh gas.
post Apr 12, 2003 - 7:04 PM
zigy
Joined Nov 6, '02
From Chicago, IL
These are one of the hints that you can try out...
1. Change the wires, sparkplugs and put some solenoid on the plugs
OR
2. Install a brand new "starter"
(if any of these mods don't change it, you can always return the parts...eg AutoZone)
post Apr 12, 2003 - 7:13 PM
west_minist
Joined Oct 27, '02
From Barbados
QUOTE (97sccelica @ Apr 12, 2003 - 5:10 PM)
gas goes old!
Is that normal?
post Apr 12, 2003 - 7:56 PM
pflau
Joined Apr 8, '03
From New York City
This is the first plug. Does it look ok??? This whole thing looks encrusted in carbon and it smells like FUEL..
fai
post Apr 12, 2003 - 10:08 PM
pflau
Joined Apr 8, '03
From New York City
ok, the those three plugs are exactly like that.. all fouled up. one of them is kinda wet too so I guessed the chambers are flooded.
now I need to get some new plugs and see what happens...
phil
post Apr 12, 2003 - 10:29 PM
Guest_Matthew_*
QUOTE (west_minist @ Apr 12, 2003 - 4:27 PM)
gas goes old!
Is that normal?
lol that's what i was thinking.
i mean what is happening to all that gas in the ground
hey minist we better go get that out before all the cars in the world go bad.
post Apr 12, 2003 - 10:51 PM
KAMiX
Joined Mar 4, '03
LOL
Igotta, you do know that crude oil is refined into petroleum/diesel/whatever before you put it in your tank?
I really don't know that much about internals and their problems pflau but it sounds pretty bad frown.gif Hate to be a prophet of doom, but take it to a mechanic man.
post Apr 13, 2003 - 2:20 AM
97sccelica
Joined Aug 30, '02
From Anaheim, CA
QUOTE (pflau @ Apr 12, 2003 - 5:10 PM)
fai
smell like gas hu?
wet plugs, quickly dry them and scrape some of that **** off and see if it helps a little but from the looks of it your plugs are dead, very dead. get new ones
and yes gas can go old, when in the ground it is crude oil, they bring it up, boil it and pump out the section they want and then add in the additive crap which is what i think goes bad by comming out of solution causing a wierd fuel mixture.
when a car goes into storage for example, the gas should either be pumped out or the car should be started once a week.
This post has been edited by 97sccelica: Apr 13, 2003 - 2:21 AM
post Apr 13, 2003 - 5:52 AM
west_minist
Joined Oct 27, '02
From Barbados
Well, everyone in the USA might have that problem.
We have car put down here for month and work after starting.
Either way, what I suspected when he mention black smoke.
Ok! Swap them out and try again.
Keep away from platimun and get a NGK copper replacement. OR buy some Nology Silverstone.
If you had some nology wires, I am sure the car would have started. Either way, when you start the car try not to use the throttle. Let the car start itself. After a couple of secs, and it does not start(something else is wrong), use he gas pedal by 8-10% throttle position.
How old is your car? How often do you drive it? What is the odameter saying?
post Apr 13, 2003 - 12:03 PM
97sccelica
Joined Aug 30, '02
From Anaheim, CA
QUOTE (west_minist @ Apr 13, 2003 - 3:06 AM)
yup
i run on California piss water, gas everywhere else is a whole lot better
post Apr 13, 2003 - 12:38 PM
pflau
Joined Apr 8, '03
From New York City
The car is a 98, got about 23k miles. Only drive it on weekends. I did not mention black smoke.. the smoke is white.
Why are you recommending copper plugs?? Do you agree that platinum plugs are actually inferior because their whole purpose of existance is to meet the EPA requirement??
phil
post Apr 13, 2003 - 4:57 PM
west_minist
Joined Oct 27, '02
From Barbados
Platinum is not a good conductor of electricity.
It was use due to its high heat capability to last long in stressful engines.
That is why iridium is better than plat. and can withstand high heat.
Since your engine is not in that category, a good pair of NGK racing plugs would do. Even better, some nology SilverStones would do good and there last very long.
post Apr 13, 2003 - 6:26 PM
Silver94CelicaOw...
Joined Oct 13, '02
From Blairstown, New Jersey
If your car still isnt running, i would highly reccomend calling a garage and have them look at it...... you dont wanna goof around too much with trying to get it run yourself if you arent sure whats wrong, leave it to the experts.
Lo-Fi Version Time is now: November 25th, 2024 - 12:46 AM
