> For those with the VIS c-one hood
post Apr 27, 2005 - 1:53 PM
Rjb23
Joined Feb 8, '04
From KY
I just got my hood and was wondering do you guys have a gap on one side, between the fender and the hood that is larger than the other side? Or will this go away as it settles?
Also how many took the sheild that covers the vent up off? Will water going through there mess anything up?
post Apr 27, 2005 - 4:37 PM
Consynx
Joined Dec 25, '02
From Pittsburgh/Clairton, PA
it should depend on how you install the hood
post Apr 27, 2005 - 6:08 PM
Rjb23
Joined Feb 8, '04
From KY
QUOTE(Consynx @ Apr 27, 2005 - 9:37 PM)
[right][snapback]279040[/snapback][/right]
I think I may need to adjust it more, any tips on getting it to line up right?
x_itchy_b_x
Joined Nov 12, '02
From Webster Ma.
i have the sheild off. its only water. and for the gaps u need to re-adjust the two bolts that hold it done possibly or maybe even the fender itself sometimes.
post Apr 27, 2005 - 6:41 PM
Rjb23
Joined Feb 8, '04
From KY
Yea I tried the fender but it wouldnt budge, I probably need to loosed the rest of the bolts that hold it just not the top ones. How many bolts hold the fender?
post Apr 27, 2005 - 7:15 PM
bloodrain
Joined Mar 3, '05
From Hollywood, FL
wonder if i will have this problem since im getting the cf version of it
To live, is to suffer
post Apr 27, 2005 - 7:19 PM
kristinw85
Joined Jan 26, '05
From Ashville, Ohio
you have 2 bolts on the bottom of the car that hold on the fender 3 bolts under the hood 1 in the door jam and 1 bolt inside the fender but you have to remove the plastic sheild around the wheels to get to it, then there are 2 more bolts under the outside light. i just took both my fenders off sunday im getting ready to put my z3 fenders on tomorrow along with my front end again i just got everything painted again. i drop the car off tomorrow too for air ride......woohoo!
post Apr 27, 2005 - 9:38 PM
Rjb23
Joined Feb 8, '04
From KY
QUOTE(bloodrain @ Apr 28, 2005 - 12:15 AM)
[right][snapback]279111[/snapback][/right]
That is what I have there is only one version that VIS makes.
Is it possible to adjust the hood latch? Because that is what is keeping it from moving over.
post Apr 27, 2005 - 10:48 PM
dustin15brown
Joined Aug 17, '03
From Bloomington, Indiana
pics?
post Apr 27, 2005 - 11:46 PM
Rjb23
Joined Feb 8, '04
From KY
Yea soon.
post Apr 28, 2005 - 9:57 AM
nik
Joined Sep 30, '02
QUOTE(Rjb23 @ Apr 27, 2005 - 9:46 PM)
Yea soon.
[right][snapback]279296[/snapback][/right]
hey what day did you finally get it?
you can also adjust the fenders
post Apr 28, 2005 - 11:46 AM
Rjb23
Joined Feb 8, '04
From KY
QUOTE(nik @ Apr 28, 2005 - 2:57 PM)
Yea soon.
[right][snapback]279455[/snapback][/right]
Yesterday, If I was you I would contact DHL and try and get your money back for shipping.
If I adjust the fenders they wont line up with the door, my fender looks like it is perfectly aligned. The latch is what is causing it to not align.
post Apr 28, 2005 - 11:58 AM
nik
Joined Sep 30, '02
QUOTE(Rjb23 @ Apr 28, 2005 - 9:46 AM)
Yea soon.
[right][snapback]279514[/snapback][/right]
i had to move my latch up a little its like 2 or 3 10mm bolts
nevermind the fender thing i have z3 fenders
post Apr 28, 2005 - 12:58 PM
Rjb23
Joined Feb 8, '04
From KY
QUOTE(nik @ Apr 28, 2005 - 4:58 PM)
[right][snapback]279521[/snapback][/right]
Yea you should be able to get your money back from them.
Yea I haven't had a chance to try and move the latch yet but that is what I was thinking was wrong. Because the front sticks up just a little bit.
post May 5, 2005 - 7:28 PM
bloodrain
Joined Mar 3, '05
From Hollywood, FL
I 2 have the same "gap" its not huge, less than half an inch, im probably just gonna get some soft black foam liner and fill it in, bit it doesnt really both me.
post May 5, 2005 - 11:49 PM
dustin15brown
Joined Aug 17, '03
^ G-H-E-T-T-O lol
post May 6, 2005 - 11:37 AM
Rjb23
Joined Feb 8, '04
From KY
Yea thats ghetto.
What washer nozzles did you guys put back on your hoods? My stock ones won't fit.
post May 6, 2005 - 11:39 AM
x_itchy_b_x
Joined Nov 12, '02
From Webster Ma.
file the holes larger and they do
post May 6, 2005 - 11:43 AM
Rjb23
Joined Feb 8, '04
From KY
QUOTE(x_itchy_b_x @ May 6, 2005 - 4:39 PM)
[right][snapback]283520[/snapback][/right]
I thought about that but I'm worried about chipping the clear coat.
post May 11, 2005 - 4:04 PM
bloodrain
Joined Mar 3, '05
From Hollywood, FL
I went to autozone and bought some "chrome" washers with the little retarded lights for like $10, fit perfect, no problems at all.
Lo-Fi Version Time is now: February 23rd, 2025 - 4:52 AM
