Which intake placement..., is better? (link inside) |
Apr 29, 2005 - 3:45 PM |
Enthusiast Joined Apr 18, '05 From Atlanta, Georgia Currently Offline Reputation: 0 (0%) |
Ok... I know the how to section includes the DIY for the ST intake. But look at the placement of that intake and then check out this one. Which is better??? It seems like the one in the how to would get colder air... but the ebay one has the simplicity of having everything shipped to you in ready to install form....
Apr 29, 2005 - 4:02 PM |
i say the fender version is better because thats where the stock air went before
Apr 29, 2005 - 4:09 PM |
Enthusiast Joined Mar 9, '05 From Charlotte Currently Offline Reputation: 0 (0%) |
It doesn't make enough of a difference on a stock motor anyway, go with what looks best or is the easiest install, it's been proven that an aftermarket air filter on a stock intake will give just as much gain as the aftermarket intakes.
Apr 29, 2005 - 7:19 PM |
QUOTE(darksecret @ Apr 29, 2005 - 4:09 PM) It doesn't make enough of a difference on a stock motor anyway, go with what looks best or is the easiest install, it's been proven that an aftermarket air filter on a stock intake will give just as much gain as the aftermarket intakes. [right][snapback]280159[/snapback][/right] And who proved this?? Thats not what Ive heard. |
Apr 29, 2005 - 7:42 PM |
Enthusiast Joined Nov 12, '03 From Crestview, Florida Currently Offline Reputation: 2 (100%) |
http://www.6gc.net/index.php?action=information&itu=11
This post has been edited by BLINKYxMUNKEY: Apr 29, 2005 - 7:42 PM -------------------- |
Heres a question about removing the airbox. I thought Id put it here instead of making a new thread.
After removing the filter I see 2 bolts that are not screwable, only able to be removed with a ratchet set. Trouble is... 7/16 size is too big, and 3/8 (or 6/16) is too small!! What the hell! I have no tool that can remove these bolts. How did you all remove yours???? Also, referring to the post above mine... at the end of the article it states.. "Keep in mind that this article isn't referring to cold air intake systems, which do provide a larger performance increase." I believe this thread was created on the topic of cold air intakes, so yeah.. This post has been edited by JoeyIsFunny: Apr 29, 2005 - 7:45 PM |
Apr 29, 2005 - 7:43 PM |
on toyota's, adding a air intake does not make too much of a gain.
on honda's, on the other had will give dramatic improvements. But the place where you located your cai will not affect the performance. You wont be able to see any difference on the quarter mile time if you had it in the fender or in the engine bay if both of them was taking in relatively the same temperature air. |
Apr 29, 2005 - 8:50 PM |
i think you will need a socket wrench with extensions. its been a while since i have done that, but i think i just ripped it out. lol.
This post has been edited by BLINKYxMUNKEY: Apr 29, 2005 - 8:51 PM -------------------- |
Apr 29, 2005 - 9:28 PM |
QUOTE(BLINKYxMUNKEY @ Apr 29, 2005 - 8:50 PM) i think you will need a socket wrench with extensions. its been a while since i have done that, but i think i just ripped it out. lol. [right][snapback]280334[/snapback][/right] I just posted that I tried with a socket wrench (well, I said ratchet set... same thing) and that it appears to be inbetween the 3/8 and 7/16 heads!! How crazy is that. I really dont want to rip them out, so if anyone else has input on how to get the bolts out that hold the lower part of the airbox in, Id really appreciate it. |
Apr 29, 2005 - 10:54 PM |
Enthusiast Joined May 25, '04 From Shreveport, Louisiana Currently Offline Reputation: 0 (0%) |
use metric sockets, since it's a toyota. everything on the toyota uses metric crap. just go to a hardware store and pick some up
Apr 29, 2005 - 11:10 PM |
Thanks.
Apr 29, 2005 - 11:13 PM |
QUOTE(JoeyIsFunny @ Apr 30, 2005 - 4:10 AM) Thanks. [right][snapback]280391[/snapback][/right] welcome |
Apr 30, 2005 - 3:25 AM |
Enthusiast Joined Aug 18, '04 From St. Louis, Missouri Currently Offline Reputation: 0 (0%) |
or just use some pliers.
Lo-Fi Version | Time is now: December 2nd, 2024 - 2:40 AM |
