Distributor cap and rotor replacement, Level of DIY difficulty? |
Apr 29, 2005 - 11:56 PM |
Enthusiast Joined Apr 18, '05 From Atlanta, Georgia Currently Offline Reputation: 0 (0%) |
Im trying to save as much money on car maintenence as possible and am just curious how difficult it is to do a cap and rotor replacement yourself. I have little under the hood know-how, so if its a somewhat big undertaking, I may steer clear. Anyone done this? Thanks.
Apr 30, 2005 - 12:20 AM |
one a scale on 1-5
it would definitly be a 1 there are 4 screws that hold your cap to the distributor.. and the cap just gets pulle straight off.. it would take you about 30. make sure you have the ignition off. |
Apr 30, 2005 - 12:24 AM |
So it wont mess up the ignition timing at all? I mean I wont have to reset it? I dont feel like running out to my car to see exactly where these bolts are haha... so you wont be messing with the bolts that are used to turn the distributor in a process such as timing adjustment?
What about the rotor?? |
Apr 30, 2005 - 12:57 AM |
the cap has nothing to do with timing. Adjusting the distributor will affect timing. The cap has the 4 plug wires connecting to it and is very easy to change. Just use a screwdriver to turn the 4 screws holding it on. Don't worry, you really can't mess this up.
Apr 30, 2005 - 1:07 AM |
Enthusiast Joined May 5, '03 From Toronto Currently Offline Reputation: 3 (100%) |
make sure you keep the correct firing order
Apr 30, 2005 - 2:01 AM |
Ahhh gotcha. Thanks alot.
Apr 30, 2005 - 10:01 PM |
Enthusiast Joined Mar 9, '05 From Oakland, Cali Currently Offline Reputation: 46 (100%) |
i've just changed out the cap on my GT and it only has 3 bolts instead of the four you're talkin about....its a pretty easy install.....IMO....
Apr 30, 2005 - 10:13 PM |
Yeah I did the whole "plugs wires cap and rotor" tune up deal myself. Saved me about 130 bucks in labor costs. Redicuous. If only I could get to the fuel filter to change that myself... Thats gonna cost about 110 to have done.
This post has been edited by JoeyIsFunny: Apr 30, 2005 - 10:13 PM |
Apr 30, 2005 - 11:13 PM |
Enthusiast Joined Feb 25, '04 From Fairfield, CA Currently Offline Reputation: 0 (0%) |
Like lagos said in the other post, it's right under your air cleaner box. It ain't that bad.
Lo-Fi Version | Time is now: December 1st, 2024 - 11:12 PM |
