> Changing fuel filter, Mechanic says have to remove engine??
post Apr 30, 2005 - 10:38 PM
JoeyIsFunny
Joined Apr 18, '05
From Atlanta, Georgia
Is it really that hard to change your fuel filter??? My mechanic said you have to like almost remove the engine to get to it cause its buried in there. I really wanna do this myself to save the 90 dollars in labor costs... Where exactly is the fuel filter, and is it easy to get to?
post Apr 30, 2005 - 11:00 PM
ghostdog
From ny to philly
you might want to start looking for a new mechanic because apparently your current one is incompetant
the fuel filter is located toward the firewall to the right-hand side. its a smallish black cylinder, you can't miss it. as for changing it yourself, go for it. the fittings can be a pain due to the angle you're working but its worth a shot
post Apr 30, 2005 - 11:11 PM
maby if you have a stock air intake, that might be in the way, but thats about it.
post Apr 30, 2005 - 11:12 PM
94GT
Joined Feb 25, '04
From Fairfield, CA
get a line wrench that fits that bottom fitting, otherwise it's easy to round it out. A pneumatic ratchet works well for the top, especially if you're changing it for the first time. (Mine was way too freakin' tight...)
post May 1, 2005 - 12:14 AM
rocky2006
Joined Aug 18, '04
From St. Louis, Missouri
i changed mine with no special tools or removing engine. just had to take out intake. pain in the ass though.
post May 1, 2005 - 6:46 AM
macavely
Joined Nov 4, '02
GO back to ur chop shop guy.. and smack him in the nuts... then kick him in the teeth... then remove ur intake box.. and get a combo wrench and socket set .. and remove it ur self.. just be carful .. remove it lines while its still held to the engine bay .
post May 1, 2005 - 7:49 AM
sapperk
Joined Mar 9, '03
From Orting, WA
Be careful with the bottom fitting, When i attempted to do mine, i bent and twisted the fuel line. But its is to get to it, just remove the air filter.
post May 1, 2005 - 10:04 AM
Junior
Joined May 5, '03
From Toronto
your mechanic is a moron, he was willing to pull out your engine to change the fuel filter? and on top of that he only was gonna charge $90?
post May 1, 2005 - 11:43 AM
DamDirtyApes
Joined Apr 22, '04
From Rhode Island
Just be careful on the bottem.... isnt it reversely threaded. Mine was such a bitch to get out, put a bucket under it for spilt gas or work on cement... You dont want to ruin asphault.
post May 1, 2005 - 12:35 PM
95gtschick
Joined Sep 18, '04
From Manitoba, Canada
lol that's a good one. i'm pretty stupid, blonde sometimes too and i changed mine myself... i'm pretty sure you can do it smile.gif
post May 1, 2005 - 1:36 PM
JoeyIsFunny
Joined Apr 18, '05
Hahaa yeah... So its the little black cylindrical shaped object just under and behind the airbox with a line attatched to the top of it by a bolt?? If so, then Im good to go.
post May 1, 2005 - 2:32 PM
DeW_H0e_GT
Joined Mar 9, '05
From Oakland, Cali
just make sure you un-compress the fuel pressure by opening the fuel cap....had bad expierences.... biggrin.gif
post May 1, 2005 - 2:40 PM
pimped6gen
Joined Sep 16, '04
From Hershey, PA
after how many miles is it reccomended to change your fuel filter? I havent yet and ive put about 30,000 on my car since i bought it...
post May 2, 2005 - 9:10 AM
toyotatech3
Joined Jul 30, '04
From colorado
every 30,000 miles. i would spray the bottom line with wd40 first
post May 2, 2005 - 10:44 AM
Why WD40?
post May 2, 2005 - 3:07 PM
open the gas cap, pull the efi fuse, and crank the motor over a few times to get rid of the extra fuel in the lines. have a few rags handy for the fuel that will leak out.
post May 2, 2005 - 8:03 PM
94GT
Joined Feb 25, '04
From Fairfield, CA
I have 250k on mine, and I've changed it once (it was the original filter). I'm about to do it again, but I think every 30k is way too excessive. I don't remember it being reverse thread. Just look at the new one to find out.
post May 2, 2005 - 9:56 PM
JoeyIsFunny
Joined Apr 18, '05
QUOTE(lagos @ May 2, 2005 - 3:07 PM)
[right][snapback]281498[/snapback][/right]
Which one is the efi fuse?
post May 2, 2005 - 10:00 PM
djspike
Joined Apr 23, '04
From WA
i was going to replace my fuel filter and went to go get it from toyota and the parts guy said toyota doesnt recomend because its a life time filter and its factory sealed and pressured.
any truth to it?
post May 2, 2005 - 10:20 PM
bs
you can change it
go to advanced auto, shucks or sumthing like that to get the filter though
STOP GOIN TO THE DEALERSHIP
Lo-Fi Version Time is now: November 27th, 2024 - 12:46 PM
