![]() Enthusiast ![]() ![]() Joined Jan 5, '05 From Upper Darby, PA(5 min away from Philly) Currently Offline Reputation: 3 (100%) ![]() |
Who do you guys think makes a better short shift TWM or TRD?
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Dec 25, '02 From Pittsburgh/Clairton, PA Currently Offline Reputation: 1 (100%) ![]() |
twm is shorter, but trd comes w/ shifter assembly.
![]() Enthusiast ![]() ![]() ![]() ![]() Joined Jul 19, '04 From Los Angeles, CA Currently Offline Reputation: 2 (100%) ![]() |
twm, its shorter and cheaper, and imo, less of a hassle to install.
![]() Enthusiast ![]() ![]() ![]() ![]() Joined Jan 29, '04 From Brooklyn moved to Miramar Florida Currently Offline Reputation: 2 (100%) ![]() |
twm is srorter & ezer to install....
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Jun 1, '03 From WV Currently Offline Reputation: 2 (100%) ![]() |
Make your own. Just take a hacksaw to your shifter. Shorter shifts.
there have been a few debates about these in the past. Do a search for "short shifter" and do some reading. Also the 7th gen short shifter fits fine and is a lot cheaper.
![]() Enthusiast ![]() ![]() ![]() Joined Aug 18, '04 From NJ Currently Offline Reputation: 1 (100%) ![]() |
yea i'm sure you'll find alot of info if you do the search cuz this has been covered alot of times. just be patient and read the posts
![]() Administrator ![]() ![]() ![]() ![]() ![]() Joined Aug 23, '02 From Seattle, WA Currently Offline Reputation: 14 (100%) ![]() |
QUOTE(Bigmeanbulldog55 @ May 1, 2005 - 8:44 PM) Make your own. Just take a hacksaw to your shifter. Shorter shifts. [right][snapback]281164[/snapback][/right] That isn't the same as getting a true short shifter. A short shifter extends the lever below the fulcrum. -------------------- New Toyota project coming soon...
i have the twm. its very very short, but you get used to it quick. i tried the trd one and i like that one too because its a little longer. either one you go with will be great tho.
IMO you cant really compare the 2, theyre 2 totally diffrent things
the TWM is a short shifter, IE SHORTER SHIFTER LENGTH the TRD is a QUICKSHIFTER not shorter than stock, just quicker throw the TRD is made to keep your hand CLOSER to the steering wheel, where it SHOULD be when your not shifting. /rant ![]() -------------------- Former Team 5SFTE pro member ;)
QUOTE(Coomer @ May 2, 2005 - 2:30 AM) QUOTE(Bigmeanbulldog55 @ May 1, 2005 - 8:44 PM) Make your own. Just take a hacksaw to your shifter. Shorter shifts. [right][snapback]281164[/snapback][/right] That isn't the same as getting a true short shifter. A short shifter extends the lever below the fulcrum. [right][snapback]281224[/snapback][/right] I knew there had to be something about them more than just the shorter shaft. I also knew that it was not as good of an idea to just saw off the shifter. I never knew exactly why though. QUOTE(presure2 @ May 2, 2005 - 12:58 PM) IMO you cant really compare the 2, theyre 2 totally diffrent things the TWM is a short shifter, IE SHORTER SHIFTER LENGTH the TRD is a QUICKSHIFTER not shorter than stock, just quicker throw the TRD is made to keep your hand CLOSER to the steering wheel, where it SHOULD be when your not shifting. /rant ![]() [right][snapback]281364[/snapback][/right] Anyone comferm this? TRD would most definately be my choice if this is the case. Is is really better for preformance driving? -------------------- Live Free, Be Happy
i compared my twm to mannys trd one. my throw is a lot shorter. you can basically just rest your arm on the console and flick your wrist to change gears. but since the stick is so short, you have less leverage. so sometimes the trd one would make it easier to change gears but with a little bit of a longer throw.
basically trd, great shifter, easy great changes, slightly longer throw then twm twm, super short throw, but less leverage to work with, makes it easy to change gears with cups in the cup holder. -------------------- 15PSI - 30MPG - Megasquirt Tuned
QUOTE(Batman722 @ May 2, 2005 - 12:25 AM) there have been a few debates about these in the past. Do a search for "short shifter" and do some reading. Also the 7th gen short shifter fits fine and is a lot cheaper. [right][snapback]281204[/snapback][/right] Cool, you use a 7th gen Shifter! ![]() This post has been edited by Drew-887: May 2, 2005 - 5:33 PM |
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Jun 30, '03 From O-town, FL Currently Offline Reputation: 0 (0%) ![]() |
I got the TRD cuz it has a shifter assembly which rulez0rs for my auto -> manual swap. Plus it's TRD.
^what he said
plus i foudn it for $140+shipping -------------------- ![]() |
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Jul 16, '04 From Los Angeles Currently Offline Reputation: 8 (100%) ![]() |
QUOTE(lagos @ May 2, 2005 - 7:22 PM) twm, ... makes it easy to change gears with cups in the cup holder. [right][snapback]281455[/snapback][/right] Very very ture and im glad i got one. |
just found this
http://toyotanation.com/forum/t77582.html 10% dis. on twm celica shifters. Promo code inside. Plus like always free shipping. |
![]() Enthusiast ![]() ![]() Joined Nov 17, '03 From New York Currently Offline Reputation: 1 (100%) ![]() |
I originally cut my shifter with a hack saw, so short that my shift knob wouldnt go down all the way and got in the way when i shifted. It made it shift faster but then i got the TRD Quickshifter and even tho it is higher, it shifts faster. I would go with TRD because, well it's TRD. It's like a stock part. It replaces the whole shifter assembly and not just the shifter rod and comes with steel bushings to replace the stock rubber ones (where it bolts to the car) so it also sits sturdier. Plus you get the sweetest shift knob ever.
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Mar 17, '05 From The Netherlands Currently Offline Reputation: 0 (0%) ![]() |
How much for the TRD quickshifter. Maybe thats my next to buy part after my projectors!
-------------------- JDM Powerplant installed, BPU coming very soon!
from a dealer here ~$200
unless they're kewl but dealers oversears have beaten our us prices before, so maybe $150 -------------------- ![]() |
Lo-Fi Version | Time is now: February 22nd, 2025 - 8:57 AM |
