> Supra Dash
post May 3, 2005 - 5:47 AM
1sickhb
Joined Dec 1, '04
I was wonderinf if it was possible to swap a supra dash in our celicas???
post May 3, 2005 - 7:57 AM
99% sure its goin to be too wide to fit into a celica.....you can i guess section it off then make it skinnier to fit to the celica....but you will need a great deal of work.....removing the celica's dash already takes a LONG LONG LONG time.........and getting the supra to fit you'd have to cut and f/g cut f/g cut f/g bakc and forth to get it to work
post May 3, 2005 - 8:15 AM
darksecret
Joined Mar 9, '05
From Charlotte
I think it's about 1 1/2" to wide, the car is almost 3" wider. It can be done but a dash requires a lot of small parts and unless you can get a whole one I wouldn't mess with it, if you're going to attempt it the best way is to cut the slack out of the passenger side airbag area, make sure you get the air ducts also and I haven't taken apart a Celica dash but a lot of vehicles have a steel reinforcement bar that runs through them.
post May 3, 2005 - 11:20 AM
same with the celica that steel bar is there
but the supra is more then 3" wider my friend
the hood alone is a 5" wide difference
post May 4, 2005 - 1:49 PM
darksecret
Joined Mar 9, '05
From Charlotte
Celica 68.9" wide
Supra 71.3" wide
It's actually less than 3", the fenders aren't as wide on the Supra.
Lo-Fi Version Time is now: February 19th, 2025 - 5:05 PM
