Koni Yellows |
Koni Yellows |
Apr 13, 2003 - 4:07 PM |
Enthusiast Joined Oct 20, '02 From Covington, La Currently Offline Reputation: 0 (0%) |
Where's the best place to Order Koni Yellows from, I'm about to order my Eibach sportlines and am going to need new struts.
Apr 13, 2003 - 4:17 PM |
I got my KYB GR-2 shocks and struts from TireRack.com, and their pricing is very similar to just about every other site for the Koni Yellows. Their service is great too.
Apr 13, 2003 - 4:32 PM |
they only have the front where's a place that I can get the whole kit, and also should I get the Eibach alignment kit, or should I just get a shop to do my alignment?
Apr 13, 2003 - 4:44 PM |
how much for the springs?
Apr 13, 2003 - 5:07 PM |
Enthusiast Joined Aug 29, '02 From ny to philly Currently Offline Reputation: 0 (0%) |
shox.com is probably your best bet, aside from groupbuys and ebay.
Apr 13, 2003 - 5:31 PM |
Also, you don't need the alignment kit. You can just get a four wheel alignment at a local shop.
Apr 13, 2003 - 9:24 PM |
Enthusiast Joined Jan 9, '03 From Concord, NC Currently Offline Reputation: 0 (0%) |
if you are comfortable to take the chance to put them on yourself then go ahead and buy the kit, but if you are having them installed professionally, then, IMO, have them align your car. |
Apr 14, 2003 - 4:11 PM |
Enthusiast Joined Oct 1, '02 From North Bethesda, MD Currently Offline Reputation: 0 (0%) |
be aware, your ride will really roughen up if you go with konis. and unless you know how to weld, you need a pro to install the shocks. also, be aware, the konis are not struts, they are shock cartridges. they go inside the struts, which are the shock housings. a lot of people get this mixed up. i'd recommend to everyone that all their suspension work is done by a performance shop. if your engine gets messed up from a mod, usually it won't run, but if you mis-install suspension stuff, that could make for an extremely dangerous driving situation. i've torn engines apart over the past few years, learned a lot about celicas, but i still have all the suspension stuff (except for strut tower braces) done by my mechanic. This post has been edited by Charlie97L: Apr 14, 2003 - 4:12 PM -------------------- 1994 Lexus ES300
1989 Supra Turbo 1990 RHD ST185RC - JDM Spec |
Apr 14, 2003 - 9:24 PM |
Maybe I'll just be better off with the KYB GR-2's what's the warranty on them? and will they work really well with a 1.5" drop?
Apr 14, 2003 - 9:35 PM |
Hey charlie. Do you know anybody that has a stock strut bar I could get cheap? (I'm gonna 'fix' it and see abut having a local place produce them.)
Apr 21, 2003 - 10:07 PM |
Enthusiast Joined Jan 13, '03 From Toronto, Canada Currently Offline Reputation: 0 (0%) |
I would go for gthe Koni Yellows if I were you. They have life time warranty on them where as KYB's don't. KYB's won't last that long since they are made for OEM parts. I have gthe Koni Yellows on and the ride is fine. Remember you can adjust the stiffness for on road or off road. |
Lo-Fi Version | Time is now: November 25th, 2024 - 11:33 AM |
