> Problem, need help!
post May 4, 2005 - 9:22 PM
exxtractor
Joined Mar 31, '03
From BC
Ok thought this had gone away:
Problem: go to start the car, here "click" "click" and nothing, same thing a few times, then it starts. Battery seems fine, the lights, stereo etc. turn on but the engine doesn't, but after two or three times it starts. Anyone know what's going on? I do have a viper alarm, could it be an alarm short? Distributor, solenoid, starter?
Help appreciated
post May 4, 2005 - 10:41 PM
spunky393
Joined Apr 22, '04
From illinois
First, just open up your fuse boxes and push all the fuses down. My off-roading jeep does this all the time.
post May 4, 2005 - 11:46 PM
Rjb23
Joined Feb 8, '04
From KY
My car does this too, it usually only does it if it is cold out. I think its the starter going out, or the connection to the starter is bad. Because I have a new battery.
post May 6, 2005 - 2:34 AM
exxtractor
Joined Mar 31, '03
From BC
thanks dude, I'm thinking its the starter, but never know could be dirty contacts, or bad solenoid, pretty sure the battery is ok. Frustrating and hopefully not the starter because that could get expensive.
post May 6, 2005 - 2:53 AM
it is the starter no doubt. Starters are common on all Toyotas (10years/100K miles) a new starter should run you about $100 if you put it in yourself.
post May 7, 2005 - 8:51 PM
nowitzon
Joined Apr 6, '05
From homosassa,florida
I know this outta nowhere and COMPLETLY off topic but batman ure celi is the shiz man thats easily my new favorite, mine is the same color and u have most of the things i want. How in the hell did u get ure engine bay that clean.
This post has been edited by nowitzon: May 7, 2005 - 8:52 PM
FOR 21 YEARS I DEALT WITH THE RAIN,
ONLY TO FIND OUT THAT I COULD STOP THE PAIN,
SO NOWITZON!!!
post May 8, 2005 - 2:09 AM
anyway I got ny new starter from here, I did have a slight problem, the connector/plug had to be modified a bit to fit properly. other than that, no problems and fast shipping
Lo-Fi Version Time is now: November 23rd, 2024 - 12:41 PM
