> Antenna HELP!, I need to stop my antenna from....
post May 5, 2005 - 3:24 PM
Guest_DJMC_Celica_*
I need to stop it from going up and down. Is there a way i can pull a fuse, or disable it without loseing signal? If not what are some other options?
Thanks,
Ryan
post May 5, 2005 - 4:38 PM
ghostdog
From ny to philly
post May 5, 2005 - 4:42 PM
chicklover345
Joined Jul 16, '03
From Boise, Idaho
go to one of these how tos switch or wire also if you want i can tell you how to make it go up and down with the switch
My car = 0-60 in ~9sec
It's slow, I know
post May 5, 2005 - 5:49 PM
Guest_DJMC_Celica_*
I just unplugged the motor, but at first i was going to do that, but i wanted to find a way without killing the radio signal, unfortunetly its not possible, so i unplugged it. Oh well! Now i need a cool antenna!
post May 5, 2005 - 10:10 PM
rocky2006
Joined Aug 18, '04
From St. Louis, Missouri
http://www.6gc.net/index.php?action=howto&itu=39
thats what i did and its great. i put the switch under my steering wheel on the right side where there was a little rectange to take out. its meant to put switches there. the new switch (got from local hardware store) is the exact same size as the insert i took out so it looks completely factory. works great for me.
post May 6, 2005 - 1:29 AM
Jdog1385
Joined Apr 14, '03
From Long Island, N.Y.
yea i did the same thing just a little differently. i posted some pics in the general discussion board. i had my motor unplugged and my signal was fine.
post May 6, 2005 - 10:03 AM
Guest_DJMC_Celica_*
Well... I am thinking about just going ahead and removing it because my Wing hangs over the antenna so i might have to do a s2000 swap!
post May 8, 2005 - 12:16 AM
cyb593
Joined Feb 22, '04
From USA
i already did mine. i would recommend putting some silicon under and around where u place the antenna if u use the same hole like i did just to make sure it doesnt leak into ur trunk
Lo-Fi Version Time is now: November 23rd, 2024 - 10:37 PM
