> Still having trouble with my 7afe, confused
post May 5, 2005 - 6:06 PM
kalark
Joined Apr 15, '05
From Bend ORegon
So, I couple of weeks ago. I posted a topic about me having trouble.
Anyways. Heres my problem
WHenever I try to start my car It wont start, but when i use started fluid runs fine.
Until I actually try to drive it. It cuts off around 3k rpm. Now A few people told me that it was the o2 sensor, so i replaced it today. and, still does it :/ so. Anyone have any other ideas?
post May 5, 2005 - 6:14 PM
mikew04
Joined Feb 19, '04
From austin tx
Either electrical or fuel problem. Make sure your fuel pump is doin its job, your filter and injectors arent clogged, and your fuel lines are in good shape. If that all looks good get your battery and alternator tested, and if those are ok replace your distributor rotor and cap, plugs, and wires.
post May 5, 2005 - 7:43 PM
CelicaST18
Joined Sep 1, '04
From Ohio
i would get new plug wires before anything else...same thing happened to me and i changed my wires and it stopped...hasn't ahppened since
post May 5, 2005 - 8:03 PM
kalark
Joined Apr 15, '05
From Bend ORegon
post May 5, 2005 - 8:25 PM
CelicaST18
Joined Sep 1, '04
From Ohio
also..if you ahven't changed your fuel filter in a while it wouldn't be a bad idea to do that too
post May 6, 2005 - 2:32 AM
94ST2
Joined Feb 7, '05
From Fresno, CA
How many miles before a fuel filter change?
post May 6, 2005 - 7:26 AM
CelicaST18
Joined Sep 1, '04
From Ohio
should be about every other oil change
post May 6, 2005 - 11:50 AM
Rjb23
Joined Feb 8, '04
From KY
QUOTE(CelicaST18 @ May 6, 2005 - 12:26 PM)
[right][snapback]283421[/snapback][/right]
Try at least 50k miles. If you car starts with starter fluid and runs fine its something with your fuel system. Start with the fuel filter and a can of sea foam. Put the new fuel filter in and then see if you can get it started. It will take a few tries because it has to get fuel throught the system again. Then once you get it running warm it up, and then use the sea foam.
Then check your plug wires, if they come off the spark plugs easy they need to be replaced. I wouldn't replace them until after you do the fuel filter and clean the fuel system out.
post May 6, 2005 - 11:55 AM
nik
Joined Sep 30, '02
short and simple
check fuel/spark/air
fuel= repleace filter
spark= check plugs, wires, cap and rotor
air= all line are connected no cracks or leaks replace air filter if need
post May 6, 2005 - 2:15 PM
kalark
Joined Apr 15, '05
From Bend ORegon
wel i dont think its the plug wires cause im getting spark. But I will check the filter and make sure everything is set and hooked up right. And i replaced my cap and rotor a couple months ago
This post has been edited by kalark: May 6, 2005 - 2:16 PM
post May 6, 2005 - 2:20 PM
Rjb23
Joined Feb 8, '04
From KY
Just because your getting spark doesnt mean anything, you may not be getting strong enough spark or you many not be getting good enough contact to your plugs.
But to be honest I think its the fuel filter, injectors and intake and stuff being dirty.
post May 7, 2005 - 12:26 AM
kalark
Joined Apr 15, '05
From Bend ORegon
so, me and my freind were looking at it today. And it was a loose wire! It was a wire loom going to the Diognostic port. wtf i dont know why it would cause the prob but oh well
Lo-Fi Version Time is now: December 1st, 2024 - 5:49 AM
