> transmission ?'s
post Apr 13, 2003 - 10:31 PM
94celicaguy
Joined Nov 11, '02
ok, the other day i started having problems changing gears. it seemed like 2nd gear didnt want to engage as easily as before. and tonight all of them seemed stiff and it took more force to change gears. someone mentioned synchronizers but i dont know why all my gears would do that at once. anyone have any suggestions as to what it may be?
post Apr 13, 2003 - 11:06 PM
Guest_Matthew_*
tranny fluid
maybe
post Apr 14, 2003 - 1:01 AM
zigy
Joined Nov 6, '02
From Chicago, IL
hmm, the CLUTCH probably worn out....
post Apr 14, 2003 - 2:07 AM
Guest_Matthew_*
don't take this the wrong way but if his clutch was going out he would still be able to move the stick into gear. if he is having problems shifting either 2 things in my opinion. 1: needs some new fluids down there or something and 2: maybe he dropped some cookies under his shift boot and he needs to take those out.
post Apr 14, 2003 - 12:39 PM
lmao i gotta! yea i'd say check ur fluid...if not that..uhhohh... biggrin.gif
post Apr 14, 2003 - 5:24 PM
94celicaguy
Joined Nov 11, '02
just got new clutch about two months ago with the new engine. i took it to this guy that worked at toyota for like 20 yrs and he said that my transmission feels strong. he said it could be that the shift linkage cables are wearing or something to do with the shift linkage. he also said that unless it has been leaking out a lot, it shouldnt be the fluid. i am dropping it off wednesday and i will keep updated. thanks, for the input guys.
post Apr 15, 2003 - 1:00 PM
prepcelica
Joined Apr 15, '03
From Lonestar state
It is the synchronizers alright that means its worn out already and it needs 2 be replace. I've also heard from another mechanic that you or somebody can do a little adjustment to the clutch. But definitely its the synchros Im having thesame problem right now. The synchros are not that expensive,its the labor. Or you can find a friend that has a know how on tranny that will help you install them.
post Apr 16, 2003 - 6:32 PM
94celicaguy
Joined Nov 11, '02
it turned out to be a worn out bushing on the shift linkage. its a $20 part so this is a big relief. he said the bushing is wear the main part of the shifting goes through the shift linkage and that it wasnt tight because of the wear.
Lo-Fi Version Time is now: November 24th, 2024 - 8:57 AM
