> tail lights removal, how to....
post May 6, 2005 - 5:45 PM
DeW_H0e_GT
Joined Mar 9, '05
From Oakland, Cali
hey,
how u remove the big pieces on the trunk? i've tried using a flat prying out the circle piece near the hatch..but it not coming off....any ideas on taking this thing off?
post May 6, 2005 - 6:07 PM
bloodrain
Joined Mar 3, '05
From Hollywood, FL
you dont need to.... in the trunk there are 3 bolts for each taillight, you need a deep 10mm socket, after u remove the bolts, just pull the taillights and unscrew the bulbs and your done, its very simple....
To live, is to suffer
post May 6, 2005 - 6:09 PM
Scott
Joined Apr 19, '05
I have a convertible, so it might be a little bit different, but this is what I did:
The spare tire cover lifts right off. Where the trunk closes, there is a grey plastic piece that runs the width of the trunk. THis sort of wiggles and pulls up and out, there are metal clip/pegs that fit into holes. From there, for trunk carpeting that is behind the tail lights, there are plastic pegs you need to get out. Some unscrew with your hands, others wiggle or pull out. Don't pull on anything hard - they break easily. That is all you need to take the tail lights out because from there, you can fit a metric wrench in to take off the 3 nuts per light lens, but if you keep unscrewing the pegs, the carpeting will eventually come out. After you take out the back carpet padding, you can do the same to the sides.
post May 6, 2005 - 6:36 PM
DeW_H0e_GT
Joined Mar 9, '05
From Oakland, Cali
biggrin.gif thanx guys, i noticed the 3 deep socket nuts but didnt know i wouldnt have to remove the trim pieces to replace the taill lights...thanks
post May 7, 2005 - 3:39 PM
bloodrain
Joined Mar 3, '05
From Hollywood, FL
np at all.
Lo-Fi Version Time is now: November 23rd, 2024 - 7:36 PM
