> Aluminum or Iron, I can't remember
post May 9, 2005 - 1:27 PM
darksecret
Joined Mar 9, '05
From Charlotte
Is the 5S block aluminum or iron, I was thinking that it was aluminum for the 6th gen and the avalon? Could a mod edit the title for searching reasons I rushed to type it in, thanks.
This post has been edited by Coomer: May 9, 2005 - 5:05 PM
post May 9, 2005 - 1:46 PM
nik
Joined Sep 30, '02
QUOTE(darksecret @ May 9, 2005 - 11:27 AM)
[right][snapback]284668[/snapback][/right]
iron
post May 9, 2005 - 4:28 PM
slipgun
Joined Jun 2, '03
From Annandale VA
little off topic but isnt the 7afe aluminum?
post May 9, 2005 - 4:51 PM
nope iron
post May 9, 2005 - 5:13 PM
FallenHero
Joined Dec 26, '02
From Alabama
Yep, you'd think you could boost them like a beast...
post May 9, 2005 - 5:20 PM
nik
Joined Sep 30, '02
yep the head and rods are the weak points
post May 9, 2005 - 7:29 PM
FallenHero
Joined Dec 26, '02
From Alabama
we don't know the limits of the 7a crank either. 5s, however, is forged...
post May 9, 2005 - 7:36 PM
darksecret
Joined Mar 9, '05
From Charlotte
Why does everybody complain about the 5S, I know the head can be an issue, but nothing that some head work couldn't fix, unless it's like the Chevy Vortec head, they use a valve seal to keep oil from leaking into the combustion chamber, the only problem is the seal was to large and the valve was limited to the amount it could open, I think .430 of lift compared to .500 on the other stock V8s. If you remove the seal then you could run a higher profile cam and not worry about the seal.
Lo-Fi Version Time is now: November 29th, 2024 - 4:32 AM
