2 Pages V  < 1 2
> Body kit epoxy?, Fusion??
post May 11, 2005 - 5:40 PM
flipside97LTD
Joined Nov 29, '03
From Hampton, VA
When I put on the VIS Invader side skirts I glued it to the car. I had problems with it fitting. After I put epoxy on the areas of the skirts that would touch the car, and on the car itself, I either clamped it, or screwed the fiberglass to the metal in problem areas. Once the glue was dry I took off the clamps and took out the screws, then used body filler to fill in the holes. Make sure to use a grinder to grind the paint off the metal where you'll be glueing the fiberglass, and scuff up the back of the fiberglass. This will insure you get a good fit. Try to smooth out any glue that oozes out. And of course if some areas are not perfect, fill them.
post May 11, 2005 - 9:48 PM
Rjb23
Joined Feb 8, '04
From KY
Thanks, flip.
2 Pages V  < 1 2
Lo-Fi Version Time is now: February 22nd, 2025 - 8:21 PM
