kinda pissed, Stupid 5sfte, check it out homies |
May 11, 2005 - 2:35 PM |
Enthusiast Joined Aug 30, '02 From Anaheim, CA Currently Offline Reputation: 0 (0%) |
QUOTE(x_itchy_b_x @ May 11, 2005 - 11:06 AM) i was talkin to guys at RCT. perforamce and they say that if i buy the universal AEM unit. install it myself wireing wise.. then tow the car to them they can tune it, dyno ect. starting at $400. hes a nice guy and owns a 500hp 3sgte mr2. so they wanna help me out basicly. he said that if i got a FPR like a 1.1 that it would richen me up in the lowerend alot and u could pull out fuel by the safc in the higher bands... iunno. stupid motors im gunna carberate it. j/p [right][snapback]285640[/snapback][/right] dont waste anymore time with the SAFC or BTM sell them and get a stand alone. things get a lot easier when you can adjust everything. -------------------- 1994 Celica GT4 WRC Edition
@gt4.wrc on Instagram |
May 11, 2005 - 2:52 PM |
john, i wonder if the fpr from the 3s would work on our rail...its a 1:1 rate..hmmm
13.6@108MPH, 5SFTE Powered |
May 11, 2005 - 3:26 PM |
whats a carborator?
May 11, 2005 - 5:08 PM |
Enthusiast Joined Jun 2, '03 From Annandale VA Currently Offline Reputation: 0 (0%) |
if you decide to get the stand alone ill buy the safc Not to sound vulcherish but I figure if you wana buy a standalone you need every dollar you can get
May 11, 2005 - 7:08 PM |
Enthusiast Joined Mar 31, '04 From Summerville, SC Currently Offline Reputation: 5 (100%) |
You know ItchyB, I was thinking about what you said on the phone, and I think the FPR idea might do the trick. Then the computer won't freak out and retard the timing and then we can lean it out up top with the SAFC. For that matter, so would larger injectors.
I still think that there's another problem that's causing that retarding and misfiring down low though... and it's better for us to fix the cause of the probem rather than the symptom, if that makes sense. You need to get the thing up and and we'll trace the problem out. By the way, how did you know that the timing was being retarded? (Besides the obvious) This post has been edited by raven_101: May 11, 2005 - 7:10 PM -------------------- -Dr Tweak, 6GC's resident engine swap wiring expert extraordinaire Click here to see my swaps drtweak@phoenixtuning.com |
May 11, 2005 - 7:34 PM |
i knew basicly cause it falls on its face as soon as it hits boost. iunno u can just tell.
but yeah im buying a fpr and a walbro next pay check. ill install it all then bring it up to u DR. -------------------- |
May 11, 2005 - 9:51 PM |
Okay sounds good. And you don't need a "rising rate" FPR, just an adjustable one, got that?
May 11, 2005 - 10:02 PM |
so u dont want want a rising?
May 13, 2005 - 11:09 PM |
Naw, because you're already rich in the upper band. You don't need more fuel as the boost increases, you just want slightly higher boost pressure all across the board. Basically the same effect as larger injectors.
-Doc -------------------- -Dr Tweak, 6GC's resident engine swap wiring expert extraordinaire Click here to see my swaps drtweak@phoenixtuning.com |
Lo-Fi Version | Time is now: November 28th, 2024 - 7:59 PM |
