> Sway bar link and Tie rod
post May 11, 2005 - 6:00 PM
Skate4mindgame
Joined Oct 1, '04
From Michigan
Yes i seen it discussed in a few topics up buuut.
First question, I went to disconnect the sway bar link from the control arm the and where you put in the Hex wrench is stripped to ****. Any suggestions? Cut the bolt and get a new link? Just disconnect the sway bar from the link all together?
Question two, the cotter pin broke off inside bolt when i was disconnecting the tie rod end =X. It broke off enough to where i got the nut off anyways. Just drill it out maybe?
post May 11, 2005 - 11:28 PM
Skate4mindgame
Joined Oct 1, '04
From Michigan
Well to answer my own question #1 looks like im cutting the sway bar links off, all 4 of the holes are stripped and my hex wrench just kinda rolls around in there and does nothing =/
post May 12, 2005 - 7:50 AM
mentat
Joined Apr 25, '05
From Canada
QUOTE(Skate4mindgame @ May 11, 2005 - 11:28 PM)
[right][snapback]285905[/snapback][/right]
gahh,
I know i'll be in your shoes when i go to do this. Maybe if i start coating penetrating grease and wd40 now i'll help myself a bit but who knows. I don't have that hex wrench im sure of it and i should probably order those bolts from napa now just incase. That is if i can get them through napa.
post Nov 25, 2010 - 10:19 PM
DanGrey
Joined Nov 19, '10
From Carson City, California
Hey buddies, found this thread in my search for the sway bar.. Been wanting to hear your thought about heelwig sway bar kit.. pros and cons? any onther brands in the market?
Thanks!
This post has been edited by DanGrey: Nov 29, 2010 - 7:25 PM
post Nov 26, 2010 - 12:15 AM
mkernz22
Joined May 10, '10
From MA
QUOTE (mentat @ May 12, 2005 - 7:50 AM) *
QUOTE (Skate4mindgame @ May 11, 2005 - 11:28 PM)
gahh,
use PB Blaster, works wayyyyy better!
Lo-Fi Version Time is now: November 25th, 2024 - 12:46 PM
