4age Trans |
4age Trans |
May 12, 2005 - 12:09 AM |
Enthusiast Joined Oct 1, '04 From Michigan Currently Offline Reputation: 0 (0%) |
How hard is it to get into a celica st with swapping in a 4age 20v blacktop, also any real advantages to it? or is the stock st tranny good enough
May 12, 2005 - 12:28 AM |
The C-52/56 bolts right in and works perfectly with the cables and such. The C-60 six-speed tranny found as an option in the AE111 would require some changes to the shift linkage setup I think.
May 12, 2005 - 2:12 AM |
The c56 comes with the blacktop for the ae111 correct? and some of the later version silvertops if im not mistaken.
May 12, 2005 - 1:48 PM |
QUOTE(Skate4mindgame @ May 12, 2005 - 12:12 AM) The c56 comes with the blacktop for the ae111 correct? and some of the later version silvertops if im not mistaken. [right][snapback]285954[/snapback][/right] Yep. -------------------- New Toyota project coming soon...
May 12, 2005 - 2:11 PM |
advantages? more power
the tranny bolts right on as coomer stated but by no means "bolts in" yes it fits but wiring like any swap is where the challenge lays |
May 12, 2005 - 2:20 PM |
hah isnt wiring always 70% of the swap =P
*edit* that is unless you are swapping out honda engines into other hondas *edit* This post has been edited by Skate4mindgame: May 12, 2005 - 2:21 PM |
May 16, 2005 - 9:23 PM |
Enthusiast Joined Apr 7, '04 From Millville, NJ Currently Offline Reputation: 0 (0%) |
what tranny swap would be good for the 7afe????
May 16, 2005 - 9:49 PM |
Enthusiast Joined May 24, '03 From Milton, Delaware Currently Offline Reputation: 0 (0%) |
Um, unless your SERIOUSLY building the 7afe, i doubt there is much advantage to swappin out the tranny. I guess in theory you could bolt up a e58, which comes stock on the ae101 4agze (lsd). But if your gonna go to the trouble of that you may as well swap. The biggest thing w/ the e58 is gonna be axles, but that can be solved with custom axles (where I'm at now).
-FAQ -------------------- AIM : FAQdaWorld
May 16, 2005 - 11:06 PM |
Enthusiast Joined Mar 2, '04 From Louisiana, USA Currently Offline Reputation: 2 (100%) |
FAQdaWorld, what are you having to do with axles? I remember a couple of years back reading that the E-series inner CV joints would work on the C52 shafts, but my info is outdated and from another country at best, false at worst.
I've got an E-51 sitting here in storage, I need to see if it has LSD. |
May 16, 2005 - 11:15 PM |
If its an e51 than the answer is no. if the tranny designation ends in 3, or 8 then it has lsd. (e53, e58, etc...)
The biggest problem i had was finding another inner cv joint for an e series, which I only recently started worrying about cuz we finally got it running. Should have it mobile within a month or two... -Ryan -------------------- AIM : FAQdaWorld
Lo-Fi Version | Time is now: January 11th, 2025 - 12:58 PM |
