> Anybody know what this is?, Under reciever and air controls
post May 12, 2005 - 10:44 PM
spunky393
Joined Apr 22, '04
From illinois
First picture
Location picture
Sorry about the links, it wouldn't let me use the img link
Well, the only info. I can give, is this wasn't in my 95 celica gt, so....any ideas?
Thankyou 6gc
post May 12, 2005 - 10:56 PM
CheesyLobster
Joined Jul 19, '04
From Los Angeles, CA
ecu
post May 12, 2005 - 10:58 PM
spunky393
Joined Apr 22, '04
From illinois
then what's under the glove box?
post May 12, 2005 - 11:03 PM
Newbie
Joined Nov 3, '04
From Colorado
The thing in the picture is the stock amp.
The ECU is actually deeper than that.
This post has been edited by Newbie: May 12, 2005 - 11:03 PM
post May 12, 2005 - 11:09 PM
spunky393
Joined Apr 22, '04
From illinois
Stock amp, that's what i was half-way afraid of. So what's going to happen when my aftermarket reciever get's here?
post May 12, 2005 - 11:36 PM
lol, yeah its the amp, not the ecu
post May 13, 2005 - 12:09 AM
97GTinKC
From KC
Unplug the car harness from that amp and connect it to the adaptor harness that you should have got with the new unit, there should be a short harness section from that old amp to the current head unit you wont need anymore .
post May 13, 2005 - 8:50 AM
spunky393
Joined Apr 22, '04
From illinois
So you're saying i need to completely unplug the amp?
post May 13, 2005 - 9:05 AM
madmods
Joined Mar 19, '04
From Scottsdale, Az
Screw the stock amp! You won't need it anymore. I completely removed mine and put my alarm there.
post May 13, 2005 - 9:26 AM
red94celicagt
Joined Jan 28, '05
From Cincinnati, Ohio
I had the same problem my man. Let me tell ya, it is HARD to get to those wires, unless you remove the whole amp alltogether. I had to reach all the way under the amp, grab the wires and unplug them. I used the how-to guide...it really helps.
This post has been edited by red94celicagt: May 13, 2005 - 9:27 AM
Speeding is only Illegal...
If you Get Caught
post May 13, 2005 - 2:08 PM
spunky393
Joined Apr 22, '04
From illinois
The harness that i bought has plugs that plug into your stock plugs. So, no wire cutting. Basically, that means i can still use that amp. Then the other end of that harness has the open wires for the aftermarket reciever. harness
[SIZE=14]Scratch this post
This post has been edited by spunky393: May 13, 2005 - 6:20 PM
post May 13, 2005 - 6:18 PM
spunky393
Joined Apr 22, '04
From illinois
QUOTE(97GTinKC @ May 13, 2005 - 12:09 AM)
[right][snapback]286334[/snapback][/right]
This is complete utter bull-crap. After more research and careful evaluation, what I have is Toyota's "Premium Sound." So, on the back, there is only one plug. I went back to my audio store in town, and told them i have a stock amp. They knew exactly what i was talking about, gave me a special plug in exchange for the old double plugs, and he said that's it. It has your basic, turn on wire for the stock and any other amp. it has 4 rca's input and output. Ground, Battery/Memory, Ignition/Accy, Power Antenna, and Amplifier Turn on. If you would like a picture, i would be glad to provide that.
post May 13, 2005 - 6:44 PM
Hanyo
Joined Aug 16, '03
From Bay area
hmm would that mean you can hook up you Ipod to the stock sound system?
post May 13, 2005 - 10:37 PM
runriot95
Joined Dec 1, '02
From Pittsburgh, PA
QUOTE(spunky393 @ May 13, 2005 - 4:18 PM)
[right][snapback]286654[/snapback][/right]
No it's NOT bullcrap! He's right on. The "premium sound" system is the stereo with the separate factory amp. The amp has one plug going into it(from the receiver) and one plug coming out of it BUT splits into TWO plugs that go into the factory wiring. In order to use the factory wiring with an aftermarket HU you MUST do 1 of 2 things: a) plug into the 2 blue factory plugs or b) find an adaptor that plugs into the 1 plug coming OUT of the amp. I found it easier and cheaper to do "a" but I believe they do make adaptors to do "b". Either way, you have to bypass the amp or the signal will get amplified twice - and no, that's not a good thing.
post May 13, 2005 - 10:59 PM
spunky393
Joined Apr 22, '04
From illinois
QUOTE(runriot95 @ May 13, 2005 - 10:37 PM)
[right][snapback]286733[/snapback][/right]
This AF harness is made to connect between the reciever and the IN harness.
So, it'll go: Reciever, After Market harness, Stock Harness IN, Stock Amp, Stock Harness OUT
post May 13, 2005 - 11:05 PM
StreetRacing10PS...
Joined Oct 10, '04
From New Jersey
ITS DEF UR ecu
post May 13, 2005 - 11:21 PM
spunky393
Joined Apr 22, '04
From illinois
QUOTE(StreetRacing10PSI @ May 13, 2005 - 11:05 PM)
ITS DEF UR ecu
[right][snapback]286742[/snapback][/right]
This is why people leave 6gc.net, because of stupid A** comments like this.
post May 13, 2005 - 11:22 PM
spunky393
Joined Apr 22, '04
From illinois
post May 14, 2005 - 5:51 PM
runriot95
Joined Dec 1, '02
From Pittsburgh, PA
So, you're using the receiver's pre-outs then? I assumed that you didn't want to use the factory amp, my mistake.
I don't know how good the factory amp is, but I think I'd rather use the head unit's built-in amp or an aftermarket amp instead.
post May 14, 2005 - 8:34 PM
spunky393
Joined Apr 22, '04
From illinois
QUOTE(runriot95 @ May 14, 2005 - 5:51 PM)
[right][snapback]287013[/snapback][/right]
Well, if you think about it, the stock reciever probably puts out 50x4 watts plus the amp to run the premium speakers. So, if my new reciever is putting out 54X4 watts, then i should still use that stock amp. Especially if there is a aftermarket harness to get everything you can out of the amp.
Lo-Fi Version Time is now: December 4th, 2024 - 2:45 AM
