Engine technical specs |
Apr 24, 2007 - 11:14 PM |
Enthusiast Joined Jun 7, '05 From Corvallis, OR Currently Offline Reputation: 0 (0%) |
Is this thread stickied? If not, I vote for it to be so. =]
May 17, 2007 - 3:43 AM |
Enthusiast Joined May 16, '07 From Newcastle UK Currently Offline Reputation: 0 (0%) |
The specs for the Euro 3SGE aren't right:-
3rd Gen Euro 3SGE 1995 on Bore: 86mm Strok: 86mm Compression Ratio: 9.8:1 Displacement 2.0L Valve Train:4v/cyl HorsePower : 173hp@6800RPM Torque 187NM@4800RPM 3rd Gen Jap 3SGE 1994-95 Bore: 86mm Strok: 86mm Compression Ratio: 9.8:1 Displacement 2.0L Valve Train:4v/cyl HorsePower : 178hp@6800RPM Torque 187NM@4800RPM or at least that's what I've read somewhere. Might need to confirm the RPM where the peak torque is developed though but if memory serves, what I have quoted is correct. -------------------- |
May 18, 2007 - 10:50 AM |
Enthusiast Joined Jan 8, '07 From Sunderland UK Currently Offline Reputation: 0 (0%) |
That's spot on "Racer" they are specs that are in my handbook that came with the car new.
Keith |
May 19, 2007 - 7:46 AM |
QUOTE(topshed @ May 18, 2007 - 4:50 PM) [snapback]559272[/snapback] That's spot on "Racer" they are specs that are in my handbook that came with the car new. Keith Hey Topshed, I live up the road from you in North Tyneside! LOL Small world! -------------------- |
Mar 2, 2008 - 8:50 PM |
Enthusiast Joined Jul 7, '03 Currently Offline Reputation: 55 (100%) |
I thought this was a good article for the 4age.
http://www.cargather.com/engineering/technical-02028.html -------------------- JDM guy made me do it.
Oct 25, 2009 - 10:25 AM |
Enthusiast Joined Oct 25, '09 From RF Currently Offline Reputation: 0 (0%) |
Hey all,
Does anybody knows the valve lift, mm - of the intake camshaft for JDM 3S-GE (3rd gen, from 93 to 12.97)??? It's part-number is 13501-88460, it's non-vvt-i Also will be grateful, if someone also knows the valve lift value for: a) 13501-88560 intake camshaft, was used on JDM 3S-GE after 12.97 (non-vvt-i) b) 13501-79016 intake camshaft, was used on JDM 3S-GE of MR-2 from 1989 to 1991 c) 13501-74041 intake camshaft, was used on JDM 3S-GE of MR-2 from 1991 Thanks! |
Oct 28, 2009 - 11:36 PM |
Hopefully these arefixed for now at least.
4age engine specs 4agze specs 4age formula atlantic specs 7age/5age info more 7age work More 7age Information about other toyota engines Toyota twin cam engines. -------------------- JDM guy made me do it.
May 1, 2010 - 7:50 AM |
Enthusiast Joined May 1, '10 From QLD, Australia Currently Offline Reputation: 0 (0%) |
Hi All,
Pardon my ignorance. I've just taken possession of a toyota celica 96 ST204R hatchback. Here's a picture of a VERY similar looking engine. Can anyone tell me about it. Ignoring the tape around the exhausts and the foil near the air filter, does this all look original or are there modifications or upgrades here. (In plain simple English please as I'm new at this. Thanks. Richard junk_1@iinet.net.au |
May 1, 2010 - 8:33 AM |
the mods i can see is the intake, header, and the upper radiator hose has been split (probably for a coolant temp sensor adapter) and the lower rad hose has been replaced with a silicone one.
the engine is the stock 5sfe 2.2 liter economy engine. -------------------- Former Team 5SFTE pro member ;)
13.6@108MPH, 5SFTE Powered |
May 3, 2010 - 2:49 AM |
Thanks for the info presure2. I really appreciate the help.
Have a great day, Richard |
Jun 12, 2010 - 4:01 PM |
Enthusiast Joined Jun 17, '07 From MN Currently Offline Reputation: 0 (0%) |
Don't forget GZ family too btw why don't you wiki some of these engines? Just make sure the source in wiki is legit.
Jun 12, 2012 - 1:01 PM |
Enthusiast Joined Apr 13, '12 From Switzerland Currently Offline Reputation: 0 (0%) |
euro 3gse has 10,0:1 compression ratio and have 175hp @ 7100rpm
Lo-Fi Version | Time is now: January 10th, 2025 - 2:48 PM |
