Turbo 5SFE, Oil line pictures |
May 13, 2005 - 2:49 AM |
Enthusiast Joined Nov 3, '04 From Colorado Currently Offline Reputation: 0 (0%) |
Hi. Could I possibly request pictures of the oil lines? I can't seem to quiet make sense of the "turbocharging your 5SFE" stickie there. And most of the links are dead. So pictures AND instructions would be great. Simple words? Thanks.
May 13, 2005 - 3:04 AM |
this might help
http://www.meisners.net/camry/5sfeTurbo.pdf -------------------- 15PSI - 30MPG - Megasquirt Tuned
May 13, 2005 - 3:22 AM |
Thanks Lagos. But the thing I was looking for was the connection for the oil fitting on the CT26. Is there a way to do it without the factory oil line? or is there a way to maybe have a machine shop make a plate, that you can tap for fittings, and connect that way? Thanks.
May 13, 2005 - 5:48 AM |
newb, rjb made his own flange and tapped them for -3an and 12 an lines, you can do that, or scroll down to my 5s buildup thread and it describes everything you need to do it another way.
13.6@108MPH, 5SFTE Powered |
Jun 19, 2005 - 10:58 AM |
Enthusiast Joined Sep 6, '04 From oakdale Mn Currently Offline Reputation: 0 (0%) |
indeed i did here's some pics
here's the flanges before i drilled em and tapped em flanges on the turbo -------------------- |
Lo-Fi Version | Time is now: January 13th, 2025 - 2:30 AM |
